Question about HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory
4650N & Duplex (not 4650dn)
Could you please confirm that it is not possible to add duplex functionality to the 4650n. Thank you
  • 59 Answers
According to specs
http://www.shopping.hp.com/shopping/data_sheet/q3669a.html
this supports MANUAL duplexing only.
Posted on Jul 29, 2009
How do I clean an HP 4650n printer
Can you be a little more specfic about what you want to clean. Outside? Inside? Do not use a regular vacuum to clean up spilled toner as it is so fine it will go right through the vacuum into the air and you will breath it in.
Aug 31, 2014 | HP LaserJet 4650n Printer
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Toner on transfer belt of an hp 4650n
Toner on the belt is normal unless it is interfering with the print quality. The belt cost around 300.00
Jan 14, 2013 | HP LaserJet 4650n Printer
How do you print duplex on a HP Laser Jet 4650n
You have to print the first side then take those prints and put them back into the paper tray to print the second side (Manual Duplex). If this were a DN model it would have built in automatic duplexing and you cound select "duplex printing" from your print setup screen and the printer would print both sides automatically.
May 13, 2010 | HP LaserJet 4650 Color Printer Manual...
I have a HP 4650n and when I print there is line through the middle of paper or picture. Replaced cartridges and fuser. Not sure what to do.
Probable : Dirty paper Xport rollers
Possible : Main molibdene shaft scratched (if line always same position)
Feb 06, 2010 | HP LaserJet 4650n Printer
Printer Duplex Function
Its highly unlikely you'll get a free answer on this web-site, so it's either fork over the money to these jokers or get an answer for free on another forum.
May 25, 2009 | Office Equipment & Supplies
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Good luck and please rate me, thanks.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
HP 4650N Will not print more than one copy of a job
make sure when printing it has all checked off in the page range box instead of pages
Aug 28, 2007 | HP LaserJet 4650n Printer
HP LaserJet 4650 Color Printer Manual Duplex & 160Mb Memory Logo
223 people viewed this question
Seeker5211
Seeker5211
