SOURCE: I have bought a Samsung
hi
check the sim card slot of your mobile. may be it get damaged . if so change the sim card slot.
this will fix the problem . and also format the phone .. this will fix the problem..
thank you
SOURCE: What's your problem? Samsung Galaxy S is not
1. Make sure that the contacts were saved to the sim without a doubt from the old phone. (easy way to determine is to put the sim and the old phone and go to sim management and copy all to sim.)
2. once you've determined that all of your contacts have been copied, try inserting the sim and transfering again.
3. You could also try bluetoothing them to the new phone.
a. turn bluetooth on both phones on.
b. go to contacts in the old phone with the sim in it. click options, there will be an option such as "send contact" or something similar.
c. send via bluetooth.
d. select all
e. send. (accept on the galaxy s phone)
Well if is a 4G phone, and there is no slot on the sides of the phone or on the back of the battery then probably is a CDMA and there is no way to input a sim card on it.
I'm Ben and -- hopefully -- I can provide some meaningful
assistance.
It seems that your SIM card is locked.
SIM CARD:
If you enter a wrong PIN code too many times, usually three,
your SIM will lock itself. This protects you from someone using
your personal information or making calls if your cell phone is
lost or stolen. You may see "PIN blocked" or Enter PUK code" on
your cell phone display. The PUK code stands for PIN Unblocking
Key. In the U.S., the PUK code is rarely provided when you get
your subscription.
If you do not have your PUK code, contact the Customer Care
customer again. Give them your phone number and once they
are sure it is really you, they will give you the PUK code.
You will then be asked to set a new PIN code. Once you have
your PUK be sure to keep it in a safe place.
Note that if you enter a wrong PUK 10 times in a row, the SIM
will be permanently blocked, and you'll need to purchase a new
SIM card.
