New kenmore air conditioner 76081. All of a sudden there is no cooling, only warm air. ice forming behind the filter, which is clean. Fan mode will defrost the ice quickly, but when change back to cool, its warm air and ice begins immediately again. Any suggestions?
  • 68 Answers
Try running the fan on high speed , but the unit probably needs some freon
Posted on Aug 04, 2009
It's forming ice
The condenser, cold coil, is getting too cold, "freezing up. Usually this is because the small tube that comes out of the temp. control is not in good contact with the coil. This problem is aggravated if the fan is run on too low a setting. To clear the problem cut off the cooling and just let the fan run. The warm air will eventually melt the ice and you will suddenly start getting a much larger volume of air flowing. Now turn on the cooling cycle and try operating the blower at a higher speed.
Oct 04, 2012 | Heating & Cooling
MY GE ROOM AIR CONDITIONER AGH08AJG1 SWITCH BETWEEN COOL AND FAN EVERY 5 MINUTES APROXIMATELY NEVER SATYS COOLING UNTIL THE DESIRED TEMPERATURE IS REACHED
Check and clean the filter if found to be dirty. It is usually behind a decorative panel below the cold air output grates (when the cold air is on the top front).
The filter is behind the large, rectangular, slotted front panel. The evaporator coil is behind the filter. The fan behind the evaporator pulls the room air through the filter and evaporator coil where it is cooled and dehumidified. It is then discharged through the grates on the top of the front.
Direct the airflow from the unit up and away or left / right to prevent the cool air from being drawn in the front of the unit (this is where the thermostat sensor is located). Use the highest fan speed to help force the air away from the intake, too. Inspect the condenser and evaporator coils (condenser is outside and evaporator is directly behind the filter. Clean if dirty or icing over. Be sure to install a filter if none was present. There are products made specifically for cleaning between the fins of the condenser and evaporator coils. Use them only as directed.
If these suggestions do not work, you may have a problem with the thermostat, refrigerant level, condenser or condenser fan.
Jun 22, 2011 | Heating & Cooling
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
Bad vibration and noise suddenly in a 5 month old air conditioner
please make sure this vibration not from the unit fixation if ok check the fan may be brockenor blower
Sep 16, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Ice forming on inside of unit air not cold
clean the filters and check the drain, to clear the drain run a jug of warm water down the pipe
Aug 19, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore 76081 cycling rapidly
check voltage when it shuts down possible motor overheating
Mar 09, 2017 | Kenmore 76081 Wall/Window Air Conditioner
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
HEAT PUMP PROBLEMS
Defrost cycle is to allow frosy or ice to melt down and not restrict the output air. The thermostat is set too low and in high humidity ice forms quickly restricting the air flow. tur up the thermostat and let the room cool gradually.
May 26, 2009 | Heating & Cooling
2 problems
Make sure your air filters are clean and you are getting enough air flow. If you are operating it with the fan in automatic and it shuts off when the compressor cycles off change it to continuous circulation.
Fan on.
Jun 05, 2008 | Danby DPAC8020 Air Conditioner
Air conditioner
Two reaons for this. One, the evap coil may need cleaned. Two, you unit may have a leak and needs freon added.
Aug 13, 2007 | Danby DAC8003D Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
