Question about HP LaserJet 3330 All-In-One Printer
HP LASERJET 3330 printing quality is poor (on & off problem). It's double printing,scattered ink, and barely printing other times. I tried a new ink cartridge, replace the pick-up roller, and did some cleaning. It sometimes works for a little while after I go into the service function (cleaning mode), but goes back to the same problem after the printer is not used for a little while. Can this be fixed or should I replace this 7 year old printer?
    Habit-Forming:
  • 64 Answers
Based on the steps you've already taken, it sounds like you need to replace the fuser unit. The fuser is what melts the toner to the paper and over time it wears out. Some service techs call it "ghosting", when it seems like it reprints a image. Check your local repair companies and tell them you need to replace the fuser, the part number is RG9-1493-000CN. This part isn't something that can be easily changed out, it involves removing the top scanner and other components. Let me know if there is anything else you need.
Posted on Aug 02, 2009
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
I have purchaed HP toner cartridge 13A from Computer Shop. But print quality of ink is poor. So, how to increase more quality of ink.
Hi
For increase the print quality go to the printer properties and go printer preference and select the device setting and set your setting.
Jun 17, 2011 | HP LaserJet 1300 Printer
My HP Laser Jet 3330 keeps sending pop-ups and PRINTS out a message with the headline: HP LASERJET DIRECTOR: shortcuts and more..This occurs every time I start (boot?) my new Compaq CQ5110F PC with Vista...
Sounds like you have a software or driver conflict. Go to hp.com Support & Drivers and check to make sure you have the correct driver for Vista. Even if you do, try uninstalling and reinstalling the driver.
Also, while at hp, check for the latest Firmware update. Go to the printers menu and scroll to INFORMATION (or REPORTS). Select that sub-menu, then scroll to PRINT CONFIGURATION PAGE. Select thi and print out the page. Look for what is beside Firmware Datecode. If it is older than what is on the hp website, print out the instructions for installing the update.
Apr 30, 2010 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 3330 with Windows Vista
no you cannot print on both sides automatically.you have to give the prints 2 times.at first the paper will print on 1 side then insert the same paper in the printer and give the remaining printout and it will print on the back side of the same paper.as you can do it manually but the automatic printing on both side facility is not in HP Laserjet 3330 printers.
Sep 29, 2008 | HP LaserJet 3330 All-In-One Printer
New problem with hp 3380
hiii...
change the fixing unit....film inside fuser.....
Sep 15, 2008 | HP LaserJet 3380 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
