Question about HP HD7500S USB 2.0 Hard Drive
Problems with HP HD7500S USB 2.0 Hard Drive USB Device Not Recognized I've gone through the troubleshooting in windows, nothing. is it likely the usb inside the drive? or the hard drive itself?
  • 416 Answers
Your device could have many isues. could be the Disk, The USB Converter, The USB Cable. best would be to check the device on a nother computer. if it does not work swap another cable, if not then better look for that warranty card.
Posted on Jul 29, 2009
HP 1TB USB 3.0 Portable USB 2.0 Hard Drive, driver
If you run Windows, there's a chance that Windows installed it's own driver for this device. Sometimes you better install the driver of the manufacturer (Hewlet Packard). Try to download it from the HP-site.
http://h20565.www2.hp.com/portal/site/hpsc/public/psi/home/?lang=en&cc=emea_middle_east&sp4ts.oid=5383421
If all fails, it might be a hardware-issue, and this makes it a better idea to contact HP for customer-support.
Oct 10, 2013 | HEWLETT-PACKARD HP 1TB USB 3.0 Portable...
For the last couple of months I've had to un-plug, then re-plug my EHD to get it to be recognized by my HP laptop. Today my HP says that the device is not regonized. Can the Signature Mini be re
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Jan 24, 2013 | SimpleTech Signature Mini 250GB External...
What make is hd5000s drive
)HP (Hewlet Packard) dos not use any specific brand of drives for all their machines, internal or external. By the part number, I see you have an USB external 750Gb (HP HD7500S USB 2.0 Hard Drive) or an HP Personal Media Drive (HD5000s) For information on the Personal Media Drive, I am posting this HP link for more information for you to copy paste in a new browser window.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00189065&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3226521
Hope this helps..
Nov 02, 2012 | HP HD7500S USB 2.0 Hard Drive
USB DEVICE NOT RECOGNIZED One of the USB devices
This may cause if your USB port is out of order. Or your pen drive is not in good condition.
Think this is helpful !
Aug 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Iomega isn't recognized on computer. Blue light is flashing on unit as well.
Is this a Windows compute? In case it is, there can be a number of causes, USB, conflicting driver letters, etc. Have a look on this article about how to troubleshoot such problems:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
May 21, 2010 | Iomega HDD External Desktop (32660) 80 GB...
Unrecognized external HDD
This message usually indicates one of two things:
1 - The driver for the device is not loaded or has become corrupted (I trust that one of the other troubleshooting steps you took included reinstalling the drivers...) or more likely,
2 - The device has malfunctioned. More likely than not, the hard drive itself is OK, only the electronics in the case has failed.
If the device is still under warranty, give Maxtor Customer Service a call and get it replaced. Of course all of the data you have will be gone unless you can convince them to send you ONLY the replacement case and electronics, not the hard drive. In which case you will have to open the old case, remove the hard drive and put it into the new case.
Jan 07, 2010 | Maxtor BASICS Personal Storage 3200...
Where can I download the hd7500s driver?
It should not need any.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
If you still cannot access it then try via the disk management panel and make sure it shows up there.
Oh and if its making any clicking noises after being bumped dropped etc. you may be in for some bad news.
Clicking often referred to as "The click of death" is usually just that.
Sep 04, 2009 | HP HD7500S USB 2.0 Hard Drive
Mounting Personal Media Drive in desktop
it just sites where ever you want. it's totally an external box.
the 1st cable is called USB-2.
and plugs into any USB2 or 3 PC port. (front or rear )
steps:
see the jack U below that goes to any USB port.
See jack P below that is Power from a 12vdc 2amp power
pack, if there is no good power pack used, the hard drive inside can not startup up and run its motor that uses huge currents.
see the rubber feet there, that tells you it can site any where and not slide about. a shelf, as desk, or top of PC case ;
enjoy,
Nov 04, 2017 | HP HD7500S USB 2.0 Hard Drive
Cannot get my USB memory stick to install on XP
I have a sandisk cruzer, titanium 512mb. Model: SDCZ3 512 I have used this to store massive amounts of data that I frequently need to access. Recently, when I plugged the device into my computer's USB, I received the following message: "USB Device Not Recognized" After double clicking on this message, I got the USB Root Hub. The last item on the tree stated: "Unknown Device." I double-clicked on the unknown device, and in the Device Status box, received the following message: "No Drivers installed for this device. If you are having problems with this device, click Troubleshoot to start the troubleshooter." I attempted to troubleshoot, but the device remains unrecognized. How can I access the data I have stored on this device? I have even tried to install the drivers automatically, but it would not istall succesfully.
xolani.
Feb 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Pny 1G travel drive
click on manual specify location and point it to c:\windows\system32 & check the 'search subfolders' checkbox.
Seems to be a Vista bug...
Troubleshoot USB device problems.
http://windowshelp.microsoft.com/Windows/en-US/Help/c39bd203-f729-47a4-8351-83291e13c8a81033.mspx
Please vote...... Good luck
Dec 06, 2007 | PNY Verto GeForce 6800GT, (256 MB) PCI...
HP HD7500S  USB 2.0 Hard Drive Logo
230 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
