Question about HP LaserJet 1020 Printer
I had a zip lock bag inadvertantly get sucked up into the printer. I can't get it off the roller. How do I remove the roller cover?? This thing seems welded together?? :) Any help would be appreciated. Thanks! Rich
    Problem Solver:
  • 5 Answers
Here are instructions for cleaning the pickup roller that I found on your printers maintanence manual. Hope it helps. (If you need diagrams to go along with the instructions, here is the link to the manual.)
http://www.partshere.com/Models/Q5911A/LJ_1010_1012_1015_1020Maintenance.PDF
Cleaning the pickup roller
If you want to clean the pickup roller rather than replace it, use the following instructions.
Remove the pickup roller as described below.
1 Turn off the printer, unplug and remove the power cord. Wait for the printer to cool.
2 Open the print-cartridge door, and remove the print cartridge (HP LJ 1010 series printer shown).
3 Locate the pickup roller
4 Gently release the small, white tabs on each side of the pickup roller by pushing them away from
the roller, and then rotate the pickup roller toward the front.
CAUTION Use gentle pressure to release the small, white tabs to avoid breaking them.
5 Gently pull the pickup roller up and out.
6 Position the new pickup roller in the slot of the previous pickup roller.
NOTE Circular and rectangular pegs on each side prevent you from incorrectly positioning
the pickup roller.
7 Rotate the top of the new pickup roller into position until the white tabs on each side of the roller snap the roller into place.
8 Reinstall the print cartridge, and close the print-cartridge door.
9 Plug in the printer, and then turn it on.
With the roller outside the printer, use the following steps to complete the cleaning.
1 Dampen a lint-free cloth with water and scrub the roller.
2 Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt.
3 Allow the pickup roller to dry completely before you reinstall it in the printer. To reinstall the pickup
roller, see steps 6 through 9 of
Posted on Jul 29, 2009
Sucked something up and it smells like its burning,nothing in the roller
You have to remove the bottom cover on vac something is jam inside causing the motor or belt to smell
Apr 20, 2015 | Dirt Devil Feather Light Bagged Upright...
I'd like to clean my Canon ip4600 so as to store it for future use. Can this be done please?
If you are not going to use the printer for a number of months, you will need to clear the printhead of ink. Remove the ink cartridges and stretch electrician's plastic electrical tape to seal the ink outlet. Put the ink cartridges in a zip lock plastic bag for storage
Remove the ink cartridge carrier clean with warm water and put in a zip lock plastic bag for storage.
Remove the printhead and soak the printhead, printhead down in warm distilled water overnight. After the printhead has soaked, replace the water with another warm distilled water bath and soak for a couple of hours. This should clear the ink from the printheads. Let the printhead dry and one it is dry, store it in a zip lock plastic bag.
Clean your printer with a damp cloth and wrap it in a plastic bag along with your installation disk and installation instructions.
Your printer and components are now ready to be stored.
Let me know if you have any more questions.
Apr 12, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
I have a Kyocera fs 1920 printer how do I replace the drum with a new one
1. Remove the paper cassette and the paper transfer unit. (Draw the paper transfer unit while pressing the buttons in)
2. Remove the developer unit.
CAUTIONS When if installing or removing the developer, do not let the magnet roller touch any part in the printer.
A. Open the top cover.
C. Remove the toner container.
D. Disconnect the developer connector.
E. Remove the developer from the printer while sliding the developer lock lever frontwards.
F. Gently flip down the magnet roller protective cover.
NOTE After removing the developer, seal it in the protective bag and place it on a flat surface. Do not place the developer in a dusty area.
3. Remove the waste toner bottle.
4. Remove the drum unit while pressing the drum lock.
I hope this is helpful,
Shawn
Dec 31, 2010 | Kyocera Mita FS-1920 Laser Printer
What can I do about my nano being washed in my washing machine?
Apple won't replace this thing under warranty if you water damaged it.  Best thing you can do is dry the thing off and put in in a zip lock bag filled with rice for a week.  The rice will **** the water out of this thing much like marriage sucks the life out of you.
Nov 08, 2009 | Apple iPod nano
My bissell 3120-3 is not sucking up dirt
if the vacuum is not sucking up dirt first check the hose to see if there is suction if you dont have suction there you need to follow the hose to the nearest connection remove the hose from there using screwdriver or some models will twist off check to see if there are any blockages, make sure the bag is not full if so replace bag with new one if needed, if bagless or if that dosent resolve the problem remove the cover plate for the roller, remove the roller and check the suction port that routes the dirt and debris to the dirt cup or the bag. you will just need to check all of the different routes to the bag or dirt cup, the best thing to have is a blower and you can blow through the different passways untill the clog is blown out, thanks I am sure that this info will help everyone if in alb visit the Vacuum Doctor, Don the doctor is always in!!!!!!!!!!!!
Oct 31, 2009 | Vacuums
Carpet roller will not turn. Vacuum still sucks up dirt
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuum roller will not spin. Reset button does not workl
The warranty should cover you for a year unless something you inadvertently sucked up caused a jam, whihc you may be able to determine or fix yourself. See if the agitator is easy to turn - if not, something is probably jamming it; if it turns in one direction, but not the other, something may be wrapped around it. If it turns easily, it's possible the motor either died early due to a defect or a broken wire.
Jul 03, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuum problem
I bought a dirtdevil 8 years ago and it's still going. As long as the motor works then you have check to see if the brushroller turns. If not then check the roller belt (take the cover apart some have screws or lock tabs on bottom panel near wheels) If the suction is low then check the vac bag, also with bag off, turn on the vac to check if air comes thru.If not the inside tube is clogged(plastic bags, small objects, ect.)Also when you open the bottom panel to check the roller belt, check the flex pipe that sucks up to the vac bag(unclogg it).
Apr 02, 2007 | Dirt Devil M085805 Upright Vacuum
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
HP LaserJet 1020 Printer Logo
586 people viewed this question
Seeker5211
Seeker5211
