Question about HP 373314-001 - HP Multibay II 8X Laptop DVD-ROM Drive DVD Drive
The notebook only loads CD-RW drives. It should load DVD-ROM
My DVD stop working. on the device manager I can only see CD-RW drives loaded. I unstillaed the devices. remover and replace the DVD ROM player and stil does not recognise DVD contents however it reads and writes to CD. Compaq nc6120 using windows XP.
Thanks for your help
  • RICCARDOP Aug 14, 2008
    into my hp nc 6120 cd-r or cd-rw work fine but dvd are unreadable !
latinmcgyver
  • 208 Answers
SOURCE: cd-dw drive corrup or file missing
use filtercheck 4.6 in cdr-zone.com forums to remove upper and lower filters.
Posted on Nov 16, 2008
RescueTechLA
  • 2653 Answers
SOURCE: optiarc dvd rw ad-7561a ata driver
weird. Try using Windows System Restore to revert back to before installing dameon tools. You can try installing it again but I would re-download just to be safe. It it happens again you might want to try alcohol 120% instead.
Posted on Feb 21, 2009
gambit3rogue
  • 106 Answers
SOURCE: Content will not load from cd's in my drive
Make sure you have the correct drivers, in most cases one must renew the drivers or should I say update the drivers.
Here is a link to get them just click on the proper Windows you are running:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3177435&lc=en&cc=us&dlc=en&submit.y=7&submit.x=4&lang=en&cc=us
Hope this helped
Good Luck =)
Posted on May 30, 2009
  • 263 Answers
SOURCE: hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Posted on Jul 30, 2009
SOURCE: DVD Drive ...missing?
I HAD THE EXACT SAME PROBLEM THIS WORKED!!!!!! This information is excellent but if you get to the point where you can't find the upper and lower filters and you go to your BIOS and that don't help and yet your DVD/CD ROM still physically works but the computer doesn't want to acknowledge it then try this it is FM......Make sure you have a DVD ready..... goto your Control Panel....System.....Device Manager.....place Your DVD in the Driver then Right Click on... Disk Drives....Click.... Scan For Hardware Changes...........It Worked for me when none of these things worked like I said FM....
Posted on Dec 26, 2009
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
Apr 07, 2011 | LG GSA H62N Super-Multi - Disk drive - DVD...
My DVD/CD-ROM drives stop working. On the device manager itb says, Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Hi friend,
Firstly you update the DVD/CD-ROM drives form device manager and restart the system,if nothing happning in that condition you need to reinstall the DVD/CD-ROM drives through CD or net.
Thanks,
Feb 25, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Dvd/cd rom not working
Are you fimiliar with the Inside of a computer box?
Apr 03, 2009 | Dell Dimension E520 PC Desktop
Playing dvd's
Inside the Control Panels, look for System. Double-click System and choose Device Manager. Inside Device Manager, find the CD/DVD and "Uninstall" the device. Restart the computer and let it re-load the driver. This might help. You can also try a CD/DVD laser lens cleaner.
Nov 12, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
CD's in drive do not load
Buy a CD/DVD cleaning disc. Try that. Maybe the read head is dirty.
Aug 29, 2007 | Toshiba (PA3352U2CD2) CD-RW/DVD-ROM...
HP 373314-001 - HP Multibay II 8X Laptop DVD-ROM Drive DVD Drive Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
