Question about Sony Playstation 3 (PS3) Console
Switches off and will not stay on - Sony Playstation 3 (PS3) Console
I have an old xbox and it wont recongnize a disc , and says dirty or broken / my name is mike
Posted on Jul 29, 2009
Brake lights r stay on when key is on goes out with key off
Do all brake lights stay on including high mount? If all stay on suspect problem with brake switch located at brake pedal. If just lower brake lights stay on ( not including high mount ) expect problem with multifunction switch ( signal switch )
Nov 08, 2015 | 2007 Chevrolet Suburban
Interior light stays on. Door ajar light on dash stays on.
door sensor is bad. switch is staying closed allowing juice to interior lights. The door switch is there. have autozone or napa look up the location for you...
Dec 21, 2014 | 1999 Ford Ranger SuperCab
Why do the brake lights stay on after the brake switch is disconnected?
be sure that brake pedal is all the way up even if you have to pull it up or thers a wire shorted
Oct 15, 2014 | Cars & Trucks
1991 JEEPWRANGLER HEAT SWITCH WILL NOT STAY IN PLACE
Slide levers like that usually move a cable. When they will not stay in place it usually means whatever they move is binding up. I suspect your heater valve is binding.
Dec 20, 2013 | Cars & Trucks
I have a nissan altima 1996. The stop lights stays on. I took the pedal switch off and still on. What should be the problem?
with the pedal switch off the lights would stay on...they only go off when the switch in depressed...if you depress the switch and they stay on then you will need to replace the switch
Feb 05, 2011 | 1996 Nissan Altima
91 honda accord brake lights stay on replaced
are you sure you the adjustment to it is correct the button in the end of the switch has to be fully depressed to deactivate the circuit
Jan 19, 2010 | 1991 Honda Accord
1998 escort zx2 dome light stays on when switch is set for door; all other indicators, chime for key in ignition etc seem OK. Light works normally in switch on and off positions.
It should stay on for about 30 seconds and go off. Otherwise, the car is 11 years old, so find a switch position which does not drain the battery.
Oct 06, 2009 | 2000 Ford Escort
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
Tail Lights stay on all the time.
under the dashboard on the drivers side. look at the brake pedal lever. there should be a switch attached. push switch in and twist to remove. then pull the button as far out as it will go. while holding brake pedal down reinstall switch. then pull pedal up to top. this will reset the brake light switch. if they stay on still, then just replace the brake light switch.
Jan 19, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Sony Playstation 3 (PS3) Console Logo
101 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
