Ok thanks my Emerson is zoomed screen is like quarter of inch to big know remote used all different remote apps but they do everything but zoom the ratio changes onky don't do is take zoom of just like to know if you can reset Emerson model number LF391EM4A screen
SOURCE: Zoom is stuck
Just check the DC power supply flowing to the Lens block control. Some times the SMD fuse blows off and power may not reach the lens block motor.
SOURCE: Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
SOURCE: Cannot find how to zoom in on the acer mini laptop
Put your two fingers in the middle of the mouse pad. And move out to the side, hopefully it should go smaller then when you do it again go bigger!
SOURCE: The picture is to big to fit on the TV screen.
It was the on the HD cable remote. the aspect ratio had to be changed backed to a 720
SOURCE: My Iphone is stuck on zoom. The lock screen and
while your iphone still on zoom, double tap the screen with 3 fingers, make sure 3 fingers, it will bring it back to normal display. I don't know how the zoom feature can get turn on but if you want to turn off this feature then go to Setting --> general --> Accessibility --> set the zoom off. hope this will help
