Question about Home
Looking for a toilet with overflow protection. urgent..
    Top Expert:
  • 4,976 Answers
Http://www.penguintoilets.com/
Posted on Nov 15, 2017
How do I prevent a toilet refill tube from slipping out of the overflow pipe?
Hello there,if you check on line you'll see there is either a funny looking piece of metal that hooks to the tube and refill pipe.They also sell a circular piece to fit over fill tube with a hole in the centre to push your tube into it.First off check and see if these didn't fall off into tank.If not Canadian tire, homedepot can help with this just have makers name of toilet or model
Apr 18, 2016 | Kohler Home
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
Toilet overflow
Unclog it and try it. It should be fine after it's unclogged.
Mar 10, 2014 | Computers & Internet
Installed a new Kohler wethworth toilet. Every 2-5 min the water refills in short spurts. Is there any reason, flapper defective?
Water level in tank might be set too high, allowing water to drain out the overflow. lower the water level in the tank. (I am assuming the flapper is ok. Flapper may have a protective disc, which should be removed after installation.)
Aug 08, 2011 | Kohler Home
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
My eljer toilet leaks between base and back. it has a built in overflow. there is no overflow tube. i change gasget but still leaks.
Look for cracked ceramic at gaskit joint might need to replace tank..I did after weeks of trail and error.
Nov 28, 2010 | Eljer & Savoy& Toilet Tank With Lid
Toilet bowl water keeps running eventhough flushing already finished or eventhough water in the tank already full. Model CST414M (elongated TOTO toilet). I appreciate your immediate assistance.
Look at float level, be sure that you are not running water into the overflow tube. Is the inlet valve closing? Pull the little tube that goes from the inlet valve assembly to the overflow tube and observe... Check the flapper valve for distortion, deterioration, or buildup. If anything is there, replace it.
Sep 26, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Replacing flush valve jacuzzi toilet
A fluid master should be universal and as long as it will allow the water to reach set mark on overflow pipe.
May 16, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
My toilet has just overflowed and the pump is
pump might have gone but probably just be jammed. womens tampons usually lol will have to have a look, have fun :D
Mar 13, 2010 | Home
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Home Logo
35 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
