Question about Dehumidifiers
What is the warranty for Westpointe dehumidifier
  • 2,177 Answers
1 yr parts and labor/ 3 yr. sealed system
Westpointe is a brand of True Value
w
Posted on Nov 15, 2017
  • Don A
    Don A Nov 15, 2017
    Further research reveals Westpoint dehumidifiers vary in warranty by PT capacity. The 50 PT model is not listed at the true value site currently and you will need to email their customer service for specifics of the warranty of your model. http://www.truevalue.com/custserv/contac...
3 Suggested Answers
  • 8 Answers
SOURCE: WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Posted on Oct 25, 2012
emissionwiz
  • 83081 Answers
SOURCE: I need a new float for my westpointe dehumidifier model #MDC -25AEN3
This site does not sell parts or have anyway to look them up for you. Sorry
Posted on Oct 25, 2016
What is wrong with a Westpointe dehumidifier when it stops removing water and displays P1? It will run this way for hours and kick in and work briefly once in a while on continuous.
Usually the P1 error indicates that dehumidifier needs to be defrosted. The unit has detected ice build-up on the condenser coils.
Unplug the dehumidifier for several hours. Then plug it back in. If the problem recurs, check that the fan that blows air across the coils is working properly. Make sure that the room is not colder than the operating range of the dehumidifier. If the problems continues to occur, you may have a refrigerant leak in the system. That will require a service call to repair the dehumidifier.
If the unit is under warranty, contact Westpointe. The manual I have for a Westpointe 65 PT dehumidifier, https://www.appliancefactoryparts.com/content/pdfs/136333-1.pdf, indicates the unit is covered through year 5 after purchase for a refrigerant system. For Warranty service, the contact point is Midea Consumer Service at 1-866-646-4332. If the unit is not under warranty, consider whether to replace the dehumidifier.
I hope this helps.
(I have seen a dehumidifier develop a refrigerant leak. It constantly froze before the leak was repaired and the refrigerant topped off.)
May 15, 2017 | Dehumidifiers
Oct 24, 2016 | Dehumidifiers
Dehumidifier started making a loud noise. Is this something we can fix?
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
Jul 27, 2015 | Midea Westpointe 50 Pint Dehumidifier
Dehumidifier manual
what is the model number to your dehumidfier Dennis
Oct 02, 2013 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
The water won't run continuously out, instead the tank fill up. I have it set up to run continuous but the tank keeps filling up. I have the Westpointe dehumidifier.
Some dehumidifiers don't require that the bucket be in place, when a drain hose is attached to the unit. I'm not sure that's the case with yours, because I'm unfamiliar with the Westpointe brand. You should also check the drain connection that the hose is connected to. It may be clogged, which forces the water into the bucket instead of draining through the hose. If you have something flexible like a long plastic Zip Tie, that can easily be run into the hose connection and slowly pulled back out, while rotating it should loosen any clogs. Be prepared for water to follow. Do not use a wire coat hanger to do this and be sure the unit is OFF and unplugged from the wall, before attempting it.
Hope this helped you to troubleshoot and solve the problem. Please let me know.
May 03, 2011 | Midea MDC-45AE Dehumidifier
A red light saying full is on. what does that mean? this is a Westpointe de-humidifiier
it means you tank is full of water and needs to be emptied
you can slide it out, dump the water ( i use it for my garden)
then replace the tank
the light should go out
Oct 09, 2009 | Midea MDC-45AE Dehumidifier
Dehumidifiers Logo
285 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
Marvin
Marvin
Are you a Dehumidifier Expert? Answer questions, earn points and help others
