Question about Dual Electronics CECT P168 Cellular Phone
How get music from memory card to the audio player in a I9 phone
I have an I9 phone and I saved my music to a memory card, but I cant get it to play in the audio player. Please help!
    President:
  • 1,884 Answers
Alternatively, use your file manager and open the directory where you have stored the music files. Click on any song and that should open the music player. If that does not happen then check the music format. It shud be the same as the phones supported one. For example mp3 or aac or whatever your phone supports.
Posted on Jul 29, 2009
How to download music to my i9 mobile phone?
Hi melissaandsa. Connect the i9 to the PC.
The i9 will ask how it will be used by the PC.
Use "Mass Storage"
You will now see 2 new drives appear on you PC.
1 will be the phones memory the other will be the memory card.
Simply copy and paste you mp3's to the "My Music" folder.
Now you will see all the folders in the "My Music" or "MP3" folder.
Your music should be in your audio player.
It may ask you to reload or something similar accept and it should relist the music.
If not try changing the "List auto gen." option if you get no list ...
You get to the "List auto gen." option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
    1.) Tap the little wrench icon to the far right on the black option panel,
     then scroll down to the List auto gen. option!
    2.) Tap the List option at the bottom of the screen, tap the Options button
     at the bottom of the screen, tap the Settings button, scroll down to List auto gen.
Now also make sure that in the "options" you are pointing at the SDcard.
One of these should help.
Dione
Feb 07, 2010 | Dual Electronics CECT P168 Cellular Phone
Music player is not playing songs from memory car
music player got corrupts in nokia 3110c its a common problem in the same mobile. just reload the software of your phone from nokia care or any mobile repairing shop. your problem will be solved.
Oct 08, 2009 | Nokia 3110 Cellular Phone
How do I add music to my CECT i9 phone. Whenever I sync with Media Player, it says it is already added on the device, but I cant find it anywhere on the phone.
I usally connet thru my USB cable. Select mass storage, download , save and play. or sync with the music you already have on y our pc, disc.
Jul 28, 2009 | Cell Phones
I am using sciphone i68+ as well.i got same promblem as u guy that i copy music into memory card then go to Audio music player but i cant use Audio music player.Just when i copy music into phone memory,it...
The i68+ have a folder in the memory card that is called My Music, you need to transfer, copy or move you songs to this folder, if you say the the memory is not enough for 3 songs, then you are saving the songs in the phone, not in memory. If you transfer from BT and it state that is full, then again you are saving it in the phone and not in memory, you need to go to the BT settings and change the saving location.
Jun 25, 2009 | Apple iPhone (16 GB) Smartphone
Problem playing music on Sciphone i68+
When you put the music on, did you drag an entire folder or just a single song. If you drag an entire folder then it will just go to the documents. I you want to listen to the song in the audio player, than you need to individually drag the song onto the E drive
Jun 09, 2009 | Apple iPhone (16 GB) Smartphone
Music does not play on my CECT i9
Try Refresh List or check in your Music Settings if the Memory Card is selected or not.
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Feb 23, 2009 | LG Shine KE970 Cellular Phone
I need to how you properly download videos and mp3 music and games and save them to your phone and play them cect i9 phone tv verison
i) u download either videos, mp3 music and games from internet and save it to ur computer, then u copy them on to  memory card of your phone....
on your memory card u will have specific folders like My Videos, images or Photos, My Music, try store videos into My Videos or Videos folder,  thereof............
ii) when try to stores videos on your phone(ur phone supports only specific video formats, like most of them support  .3gp videos...........), try using good video converter to converter ur video files(which are in other format such as .vob, .dat,  .wmv.....)and play them on your phone...even after this u may encouter message "invalid file", so try choosing best video converter which convert your video to .3gp(compatible to ur phone)---------------
Thanking you
M. Sridhar
Nov 17, 2008 | Dual Electronics CECT P168 Cellular Phone
I9 downloads
For music i use and LOVE Blubster..go to www.blubster.com select the free download--have never had a problem and always find all the songs i want..and its FREE..download the music to your computer then plug the USB cord to the phone to the computer and it should pop up the files..save them to your music file in device F(your memory card)--device G is the phones memory and if you put them there it will tell you the file is to large..
For videos and music videos..my favorite and FREE site is http://www.mv3gp.com/ I love that site..
3gp is the format all cell phones use for video..so if you need more google free 3gp videos and more sites will pop up..But these are just the TWO i use personally and LOVE.. for the videos same as music drag the file to the F device in your video files..Voila..
Then you can find them in your phone under your documents icon and under memory card..or in your multimedia icon and audio or video player
Nov 14, 2008 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
189 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
