Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Olympus C5050 lens
By fred-2 on Nov 23, 2007
I have an Olympus model C505 about 3 years old and, suddenly and without dropping or otherwise shock, the lens won't open even though it sounds like its trying.
There's no troubleshooting information in guide that would indicate if and how the lens would unscrew or otherwise allow access to see what's wrong.
Best Solution
posted on Jan 14, 2009
Very Helpful)
pishta68
Rank: Wiz
Rating: 84%, 301 votes
remove the 11 screws that hold the clamshell body together and remove the 4 screws that hold the plastic lens assy onto the chassis. Once you get the screws loose, you need to release the 2 ribbon cables that go from the lens to the camera chassis. When these are released you can pull the lens out far enough to get to the 2 screws that hold the CCD board to the lens. Once these are removes, the lens can now be pulled from the chassis. now remove the 3 screws that hold the lens assy together, they are all in the same direction and the one screw on the side that holds the lens sensor clip on. once these are all removed, carefully pull the 2 ribbons through the outer case while lifting the outer case straight up. Now you have the bare lens assy. It is in 3 pieces. The outer part and the inner part remain on the same plane, while the middle part that has the gear on it twists counterclockwise as you look at the back of the lens. If you cant twist this piece, your lens is jammed and youll have to work to get it off. Normally the lens can be retracted by turning the exposed drive gear on the lens assy, but it is very stiff, you can work it back and forth finding the rough spot and maybe work it out, but if the lens was compressed without motor power, you probably knocked the inner shell out of its helical track, a,nd now the guide pins are buried into the relatively soft plastic outer shell. It is a very labor intensive job but it can be done if you have a worthless camera and are not afraid to give it a go. you can sometimes buy complete lens assy's on Ebay for 50.00. I have fixed about 3 of these but Im on one now that is really frozen, maybe too far gone.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 15, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
When I said sell on eBay I meant of course for parts - I think I got about $100 for my old non-working 3030
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Sell your camera on eBay and get a new one unfortunately. I'm in the same position - its the third time the lens mechanism has failed on similar models - the two previous ones were C-3030s.
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
it's just a surveillance camera. How can I install it on my PC?
Answer
want to buy digital cameras for my 7 & 5 yo granddaughters who have both shown great ability... (More)
Answer
my battery compartment cover is broken and i need a new one
Answer
Cannon PowerShot A560 Camera ~have lost view/display in window, but still takes photos. Have I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Cameras Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
