Question about Kenwood KW85 Air Conditioner
Making clicking noise from the back bottom, possibly the fan?
  • sugamagnolia Jul 29, 2009
    Thank you for such a quick response and a correct one at that.... You rock!!
  • 11,896 Answers
That would be my guess as well. Fan may be off center or rubbing against housing. I believe the cover of the unit should be easily removed by just taking out the screws and lifting off the cover
Posted on Jul 29, 2009
My 2004 t&c 3.8 is making a weird sound like a
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Thud in trunk at take off
There is N-number of possibilities for the car to make thud noise or any other kind of noise.
These will help.
Thanks.
Nov 28, 2012 | 2010 Toyota Camry
Chevrolet k1500 whining noise
Its actually from where the noise is coming from.Front end or rear end.From engine area or from inside from steering or from breaks.
There are N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting these problem,i suggest you to refer the help links mentioned below.Its a complete solution with proper explanation to identify the cause of problem:------
Click the link below:-----
These will help.
Thanks.
Nov 28, 2012 | Chevrolet Silverado 1500 Cars & Trucks
The hard disk and/or the cooler fan makes a bad noise
If you are experiencing noise from in your laptop then it can be the Hard Drive or the Fan as you mentioned.
if it is a clicking noise and the system boots up but seems it is kinda slow make sure you back up any personal data from the system possible HDD failure if the system works fine with no problems and there is noise possible it can be the fan.
Does the noise happen every so often or does it happen if you use the DVD rom? if it happens most of the time it can be the fan or if this happens as soon as you turn the power on then it can be the fan, Possble something it in it's way making the noise possible the fan may have gone loose and is touching something else inside the system or just a simple cleaning may do.
Really depends if it will be a replacement Fan then I guess you may need to call Lenovo for the issue, the Fan will be inside the machine and is hard to remove without removing the Bottom Plastics to see the whole inside of the unit.
One suggestin is bring it to a local tech to have it checked if it is just a cleaning issue with the fan or if the HDD is the one causing the noise.
Have a nice day, I hope this helps.
Jul 23, 2011 | IBM ThinkPad T40 2373 Notebook
My Kenmore refreigerator is making an extremely loud noise as it runs; just started tonight; we turned it off and are taking food out for the night. We bought it new in May 2003. Is this a common issue? ...
repost where is noise coming from inside of unit or from back of unit.... could be one of three possibilities... compressor is making noise ,indoor fan which is usually located in freezer section behind back wall could be hitting something or failing... or the fan on bottom of unit in back rear may be making noise.... check it out and see where coming from and repost with better description.... good luck to you ....
Jan 27, 2011 | Kenmore Refrigerators
I have a Kenmore elite bottom freezer model. The fan started making a funny noise.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace the blade. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged and rubbing against it. Check the rear condenser fan as well for faults. It is possible that the noise is coming from the motor itself. If that is the case, you will need to replace the affected motor.
Aug 23, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer is not cold, defrosted everything,fans running,back sealed so cant get to any coils.making a clicking noise.flipped circuit breaker .never had prob before temp settings are on coldest settings ...
Is the clicking noise coming from the back side bottom ofthe fridge? If so its the compressor trying to kick in. Usually this is a death nail for a fridge. You say the fan is running is the fan inside the fridge fzr running and is there a fan under the backside of the fridge running? let me know and I will be glad to help more. Hope your day gets better
Aug 16, 2010 | Refrigerators
Condensor Fan Won't Come on...it tries but won't stay spinning.
The click noise make me think you have a relay on the main board that moves, but has bad cntacts, thus not providing power to your fan. The possible good news is that if your model was manufactured between Jan 05 and July 06, you can get a replacement part (the motherboard) at no charge from GE.
Nov 22, 2009 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Clicking of Ge Model PDS22SBRBRSS; serial No; DL047209
IF the below mentioned information does not help, then contact a elextrical engineer worksman who can check the circuit board as it might also cause a short cicuit.
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
May 31, 2009 | PDS22SFS Stainless Steel
Cpu fan noise problem
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Sep 16, 2007 | Intel D915GAG Socket 775 Motherboard -...
Kenwood KW85 Air Conditioner Logo
49 people viewed this question
Top Kenwood Heating & Cooling Experts
john h
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
