Question about Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME
Peerless faucet with a squeeky hard to turn handle.
I removed the cold handle to find a plastic part that squeeks and is becoming difficult to turn.
  • ccnsport Jul 30, 2009
    How do I remove the cartridge?
  • 117 Answers
You can get a new cartridge for it or try pulling it out and putting some faucet grease on it the cartridge should come apart put grease on everything with a black o ring and you should be good to go
Posted on Jul 29, 2009
Peerless faucet sometimes won't turn on
It sounds to me like the rubber o-rings are getting old. Try posting your concerns on the Peerless Customer Support webpage. They can help you identify the model of your faucet and what repair kit to purchase. (Repair is fairly easy, the faucet is repaired in-place).
Customer Support Peerless Faucet
Apr 16, 2014 | Peerless Industries Peerless& Single...
Low pressure from faucet, how can i remove screens
I had the same problem. To fix it you remove handle and pull cartridge out and clean the water port out. To remove handle it take a #10 star driver. Also on the hose connection ( white plastic) it will unscrew from the hose as well a sun lip from the upper section. There is a screen in there you'll have to clean out.
Nov 10, 2013 | Peerless Chrome 1-Handle Pull-Down Kitchen...
Stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
I have a single handle shower faucet, turn all the way and you get only hot water.... It has been dripping over the last few weeks when off, hot water. now it's a steady flow. How do I adjust...
hi there:) your problem is caused by the cartridge inside the valve body. could be one of 3 things...1)the cartridge is damaged 2)hard water build up 3)foreign matter. it is not to difficult to replace it yourself: first turn off the water then find the set screw, which holds the handle in place, usually located at the base of the handle and remove it. (look closely/carefully cause it's hiding) then remove the escutcheon ring and the trim sleeve to expose the "bonnet" (lock ring) and remove it. (ritey titey lefty loosey) now you can remove the cartridge and inspect it for debris/damage. if you need a new one just take it w/you to any plumbing supply including home depot and/or lowes and they will help you find it. here is the installation/owners manual from peerless: http://peerless-faucet.com/customer-support/find-repair-parts/documentation/P8760.html hope this helps but if you need anything else just ask:)
Jul 30, 2011 | Peerless Industries Peerless& Single...
I have a very old single valve peerless tub/shower faucet that leaks out the spout when turned off. I removed the knob and there seems to be a plastic part that surrounds the stem and may also serve as a...
im sorry i dont know how to explain step by step what you have to do but i know what you are talking about and its called a diverter. they get stripped out and thats why the spout leaks. they are not difficult to replace depending on the model but some of them have to be sweat apart with a b-tank.
Feb 05, 2011 | Delta Faucet Peerless& Shower Faucet...
Just had a contractor give me an entire new bathroom. The Peerless Single Handle Tub And Shower Faucet will only go from 90 deg down on the cold side to straight up. it want go to the hot side. What is the...
if u have the paperwork for the unit--in it will explain how to adjust the anti scold settings single handle units are shipped in cold setting u have to adjust the hot -- remove handle and on shaft will see blue and red clips adjust the red till hot water is to ur liking replace handle
May 18, 2010 | Peerless Industries Peerless& Single...
My delta two handle bathroom faucet the cold water handle is hard to operate tried wd40 on it and it worked for a while but it got hard to operate again
They have a lithium faucet grease for stems at hardware stores Home depot or Lowes. It a gease to help free up for movement of handle if they don't have it try a Plumbing supply house they should sell to public.
May 04, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
I Have a single handle peerless kitchen faucet that's making a shrill noise,and the water pressure is very weak.
Possible causes:
1. you have a air pocket t in the heated water system. You will need to bleed the system.
2. As to pressure, you may have knick in pipe somewhere due to worned plastic pipe.
Apr 20, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
2-handle faucet handles both rotate "on" counter=clockwise
Here's the solution from Delta:
On a two-handle kitchen or lavatory faucet, if the handles rotate in the wrong direction, simply rotate the right stem stop assembly 180 degrees. This will change the rotation of the handle to the other direction.
Jun 23, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Delta Faucet DELTA/PEERLESS FAUCET CO. 25901 TWO HANDLE LAVATORY FAUCET - CHROME Logo
510 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
