Question about Thetford Norcold RV Cooler/Freezer
Fault code on norcold refer model 640.3 reads "no" "co",how do I reset
  • munelmo Sep 19, 2009
    Fault code on norcold refer model 640.3 reads no co, how do I reset
    Problem Solver:
  • 15 Answers
U must take into a dealer or have a mobile tech to reset the board
Posted on Jan 29, 2010
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
Want to reset board on N611 norcold ref
The Norcold board reset is done by jumping a pin terminal to ground. There are several steps involved but it's all pretty straight forward. Here is an article on the steps of doing this: Norcold Refrigerator in Lockout Mode do you need to reset your power board
Jun 09, 2011 | Thetford Refrigerators
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold rv cooler code needs reset reading no co
u need to take into dealership or have a tech reset the board if not done right u can blow your board out
Sep 19, 2009 | Thetford Norcold RV Cooler/Freezer
Error message reading NO co is beeping.
I have done a bit of google research and this code probably means "Not Cooling" Due to a power interruption or sometimes if you do the initial cool down from 12v (instead of gas or AC). There are a couple of other causes but often all the unit needs is a reset. I found some details and instructions here but they don't specify an exact model. There were other details here but they refer to pages that are no longer available..
This should put you on the right track. Just do some more googleing if these details aren't specific enough.
Aug 16, 2009 | Thetford Norcold RV Cooler/Freezer
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
683 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
