Question about Plumbing
Trying to locate two hinge pins for a servowarm ''master radiator'' which is in fact a wall mounted boiler with a swivel door type radiator on the front and one of the hinge pins is leaking. Where can we obtain hinge pins to fit ourselves or to be fitted professionally. We are aware that the firm of Servowarm no longer exists but wonder if anyone has spare parts.
    President:
  • 2,976 Answers
If you are just looking for the pins, go to any local metal fabrication shop with the dimensions you need. Ask for low carbon steel. Have the one end heated to light cherry / white hot and peened to the shape of a head.
Posted on Aug 29, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Can I reverse the door?
Janet,
Most of the time you can. If you look on top of you refrigerator, and you see some button covers on the side opposite from your hinge, you should be able to reverse the door. Second, open the doors and see if there are button covers on the face of the door frame opposite the hinge. If you have both, you should be able to change them. You usually will need a Phillips screwdriver, a flat blade screwdriver and usually a 3/8" socket or nut driver. Start with the freezer door and take the hinge loose on top and swing the door open and lift up on it and remove it. Next take the middle hinge loose so that the top of the refrigerator door is loose and you can then lift up on it and remove it. Take the grill off of the bottom front of your refrigerator and you will see where the bottom hinge is located. Remove the hinge and move it to the opposite side and then loosen the swivel pin and move it to the opposite hole and re-tighten. On the middle hinge you will need to turn it over from the direction it was originally mounted so that you can re-install it. You will also need to switch some pieces on the bottom of each door to the opposite sides so that each door will operate properly. Once all pieces are switched, including the handles, just re-assemble in reverse order that you took it apart. Hope this helps!
Jul 09, 2015 | Refrigerators
Car door is sagging
Take a good look at the door hinges. Often, there will be replaceable bronze bushing inserts in the hinges, and the hinge pins are also prone to wear, especially if the recommended lubrication is not done.
If the bushings and/or pins are not replaceable and the wear is in the hinges, the hinges willl need to be replaced.
Other possible causes are loose hinge mounting fasteners, failure of the door or "A" pillar (for front doors) at the hinge mounting location(s) due to rust or physical damage, and (of course) collision damage to the door or door frame.
Oct 04, 2012 | Toyota Celica Cars & Trucks
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Servowarm Boiler Elite 30
try parts center web site or mjt controls both are helpful and have phone numbers to contact technical dept.
Nov 17, 2008 | Water Heaters
Removal of door gromet
I would just get a unibit and drill a hole, put some protective loom and run the wire through, i cant really tell you how to correctly remove the gromet because i need to see it in person.
Good luck..
Jun 12, 2008 | Volkswagen Beetle Cars & Trucks
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
