Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Blue color gun off line
Need assistance relining blue color gun i've never had a problem with
the set untill the blue gun went off line
  • 934 Answers
Re: blue color gun off line
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Posted on Dec 07, 2007
  • 1,694 Answers
Just to add second opinion, premtech's Solution is right on....
mechcanical alignment should not be confused with electronic convergence alignment........................T.
Posted on Dec 31, 2007
0 characters
3 Points
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Blue color gun just went out of wack. cannot re adjust. Blue lines make horizontal hour glass. down on top and skewed up and to left on bottom
Sounds to me like a convergence problem. There are two convergence amplifiers inside the tv that keep the red and blue lined up with the green tube. This repair requires solder/desolder equipment and test equipment. What needs to be done is the parts need to be replaced on a circuit board. Most repair shops charge about 200-350 to do this repair. This set was very expensive and has many years of good life in it. If the service person says they need to replace the entire circuit board they are wasting your money. This board can be rebuilt by anyone with some experience in tv repairs. I would think that if a repair on that set doesn't exceed 450 most people would fix it. The set should stay in the home although some shops prefer to remove the circuit board to return to their shop for repair. Good luck, Russmann.
Apr 28, 2010 | Pioneer PRO-710HD 64" Rear Projection...
I am having trouble with the blue gun. It would
Be shure the guns are set properly follow below:
  • Pre Heat Run should be finished.
  • Be sure Screen Color Temperature setting is in the COOL mode
  • Room Light should be minimal.
  1. Go to I2C ADJ. Mode. (With power Off, press the INPUT button on front panel and then press the POWER ON button then release. The Service Menu is displayed.)
  2. Set R DRV (COOL) to center data value (3F).
  3. Set G DRV (COOL) to center data value (3F).
  4. Set R, G, and B CUTOFF (COOL) data settings to [80].
  5. Adjust Screen VRs on Focus Pack fully counter clock wise.
  6. Choose SERVICE item [1] of I2C ADJ. Mode. Select CURSOR RIGHT and the Vertical will collapses.
  7. Adjust any Screen VR. Screen VR should be turned clockwise gradually until that particular color is barely visible.
  8. Repeat for the other two colors.
  9. Exit SERVICE MODE by pressing the CURSOR LEFT on remote.
  10. Exit SERVICE MENU by pressing the MENU key on remote.
Oct 12, 2009 | Hitachi 51F500 51" Rear Projection...
Further assistance needed
I just replied you and here once again...
Please pull front speaker grill and find focus block, fixed at corner having 6 control knobs on it.
Find Blue Screen control knob there.
Put your TV in AV mode to get dark screen and just press Display button on remote to have AV display.
Now slightly rotate control knobs counter clock wise until thin lines (retrace) disappear. Job is done and put back speaker grill, press display button again to disappear screen display.
Dec 13, 2008 | Sony KP-51WS500 51" Rear Projection...
The Guns?
You will need a new CRT ( Blue Gun) they are fairly exspensive unless you can find one used. let me know if you need more assistance.
Jun 08, 2008 | Sony KP-57WS500 57" Rear Projection...
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Color went out
what do I need to do to get the color back on my t.v.>>
get rid of boy friend! problem fixed!
sorry i just could not resist!
doesn't this set have Auto color balance resets individual picture tube guns (red, green, blue) to maintain consistent overall picture quality for the life of the tube.
Dec 10, 2007 | RCA P52960 52" Rear Projection Television
Tv problem
seems like your tv got convergence problem . try setting up the convergence , use remote . if it does not help you may need to change convergence ic * 2
Oct 01, 2007 | Panasonic PT-47WX49 47" Rear Projection...
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE.
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
344 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
