I am sorry to inform you but this unit is stand alone only. You cannot connect this to a computer. There are no cables or drivers made for this unit to connect to computer. The connection is only for printer.
The computer is not detecting your printer. Here's what you need to do:
1. Check all the connections or Reset the connection between your computer and your printer. 2. Press and hold the power button of your printer for 5 seconds to do a power cycle. The printer will turn off. 3. Turn it back on. 4. Print something.
If no go,
1. Uninstall and reinstall the driver of your printer. You can access the driver in Control Panel>Add and Remove Programs. After un installing the driver, put the disc of your printer into your computer's DVD player. Follow the onscreen instructions.
Welcome to FixYa! If you still have the installation disc that came with the router, you can go ahead and run the disc and follow the instructions. The Cisco Connect Software will be installed when you run the supplied Setup CD or Easy Setup Key on a computer. Once Cisco Connect is installed, you can then use its features to easily manage and share your network resources.
QUICK TIP: Create a Desktop shortcut to launch Cisco Connect easier. Windows XP
Step 1: Click on the button and select All programs.
Step 2: On the All Programs sub-menu, locate and select Cisco Connect. This should launch Cisco Connect and take you to its main screen.
NOTE: If you are unable to locate Cisco Connect, it may not be installed yet. Download the latest Cisco Connect setup wizard from the Cisco Support page. After downloading, click on the Cisco Connect icon to launch the installation wizard.
Hope this will help...Thank you for using Fixya...
1. Download the Samsung PC studio . 2. Double click the exe file to run it. 3. Follow the instructions given to you. 4. When installation has completed, the program will open and you can connect your Samsung mobile without any problem.
I hope this information will be helpful. Thank you for using FixYa!
Welcome to Fixya Support I am Michelle, and i will be assisting you regarding the issue
Please refresh the wireless connection
in order to do so please press and hold down the connect button at the bottom of the mouse and the connect button on the receiver together and release both the buttons together.
this should referesh the wireless connection.
Load the installation CD in computer. Choose your language, accept the licensing agreement and follow other on-screen prompts.
Connect the Logitech webcam's USB cable to your computer. A few minutes may pass while your computer detects its new hardware. A screen should then appear with an image from the newly installed Logitech webcam.
Follow on-screen prompts as the installation program performs an audio configuration.
Restart the computer and start enjoying your Logitech webcam.
Hope you got it.Dont forget to Rate[Let me Know if you need further assistance]..Thanks for Connecting FixYa...
Even if you configured the program to keep you signed in, whenever your internet connection fails, you'll need to sign in again or every time you turn on your computer. If you keep you computer on for 2 weeks without any connection failure, then definitely, it'll work for you, but I am afraid that any internet connection will continuously keep connected without any interruption.
Good luck.
Thanks for using FixYa.
Sounds like your reading right from the manual. <grin>
Try this.
Connect the camera to the computer via the usb cable. Set the mode switch to playback and press the power button, then:
on your pc go to Start>All Programs (or Programs)>Canon Utilities and find Canon Window. Double click on it and it should fire the program. Let me know if you have any problems. If not, feel free to rate my solution.
First check the Bios CMOS setup is the hard drive and cd are detected what you connect the device to the computer. Then check the data cables that connected into the mother board.try it and inform to fixya.com
Please click here for the correct connections to use when when connecting this unit to Cable. Click Download on the top right of that page to save a larger image to your computer.
