SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at [email protected] for more information.
Thanks!
Robbie
SOURCE: Feed Dog problem
I listened to all that...and none of it worked...so I took the plate off and gave it a good clean. Still nothing. If your machine's a bit old like mine or tends to get stuck...physically lift up the feed dog with your fingernail or a flat screw driver or something (once the plate is off), then push the feed dog lever across and release the feed dog. It should hold in place if nothing else has worked...woo!!! :)
SOURCE: feed dog problem.
Open the bobbin case door and there should be a lever sitting off to the right. It moves from left to right. For the feed dogs to be in the up position the lever should be to the left.
SOURCE: singer stylist sewing machine 534 is not stitching
Feed dog drive gear(2) are plastic and are probably stripped. Always replace them in pairs. While you are at it replace both hook drive gears as well. It will run as good as new.
SOURCE: repair singer 502 sewing machine
You can get the fears quite easily and fit them yourself and if you email me I can attach full instructions.
[email protected]
