Question about Singer Sewing Machines
Singer 3116 machine has jammed. Can not turn wheel to move needle.
Did you check the bobbin? Could be what's jammed
Posted on Nov 15, 2017
  • 98 Answers
Make sure there isn't thread jammed in the hook take out the bobbin case and look
Michaelle
  • 65 Answers
SOURCE: Hand wheel will turn backwards, but not forward
here is some troubleshooting
Download your manual.
manual
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Ok I know that youve checked this, but I have to ask.
Pg 39
Check and make sure the reverse lever isnt engaged.
I'm looking at pg 27 and see you have a traditional bobbin casing (not a drop in) make sure your bobbin is wound well and the case is inserted correctly. (they are picky)
Change your needle make sure its in right and tight. (I have bent many a needle just slightly, and it causes huge issues with this particular type of bobbin casing)
Pg 35 gives a test for the bobbin tension. If your thread rolls, the tension is too loose, OR the case may have gotten damaged.
Lets see if this helped.
Good luck
Posted on Jan 27, 2009
ashish13
  • 75 Answers
SOURCE: singer 3116 - change the needle
I'm giving you a direct link to the Manual on page 82 of which is explained the procedure of removing the needles so you can attach new ones the same way...
Lemme know if it helps :-)
Posted on Feb 12, 2009
SOURCE: Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Posted on May 01, 2009
  • 25 Answers
SOURCE: machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: necchi 534FB
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
Posted on Jul 18, 2009
Hand wheel stuck
Check to see if the needle is jammed into the fabric. Try pushing the REVERSE on the machine and give a little push to the hand wheel.
Jun 20, 2013 | Singer 3116 Simple
Singer esteem
when you have a machine jam up there is something wrong with the parts
inside, only a sewing machine shop can tell more after they check the machine.
Apr 16, 2012 | Singer 3116 Simple
The wheel that lowers the needle will not move forward, it will move in reverse to some extent. I have rethreaded , and pulled out the bobbin casing and no change.
Do not turn your wheel to the rear! You will mess up the timing. You have thread or cloth caught in the bobbin area. Clean your machine as per your manual.
Oct 03, 2010 | Singer 3116 Simple
My singer simple keeps jamming. I know the thread is caught underneath, near the bobbin but I can't turn the hand wheel either way.
Is your needle position high enough that you can remove the needle, and then maybe use a straight pin or tweezers to pull out the thread?
If needle is down try loosening the screw that holds it in and see if you can push it down into the casing enough to clear it for removal. good luck
Mar 21, 2010 | Singer 3116 Simple
How do i thread this? need visual guide please. i can hear something moving, but pedal isn't going up/down.
The "pedal" is the foot pedal and it powers the machine and does not go up and down.
The needle and needle bar go up and down.
If there is a smaller wheel in the center of the handwheel (wheel on the right side of the sewing machine), make sure it is tight. Turn to the right (toward the back of the machine).
You can find threading, bobbin winding instructions and a manual at the Singer Company website.
Mar 12, 2010 | Singer 3116 Simple
Singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Mar 15, 2009 | Singer 3116 Simple
Mar 12, 2009 | Singer 3116 Simple
How to re-insert bobbin shuttle
maybe one of the parts diagrams at the Singer site would help? or us the contact there?
Oct 29, 2008 | Singer 3116 Simple
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Mar 24, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
