Question about Black & Decker Tools & Hardware - Others
How do i fix new belt to planer bd713 - Black & Decker Tools & Hardware - Others
  • David Ford
    David Ford May 11, 2010
    I tried that model number on the B&D site with no luck could you recheck and let me know.
Older model - managed to heat some water in the microwave and stretched the belt over the drive wheels when a bit more pliable due to thermoplastic nature of drive belt - used thin teaspoon handle as tyre lever and seems to be fitted securely now.
Posted on Mar 30, 2010
I need help changing the be belt on a Dewalt 734 planer.
Installing a New Belt
NOTE: No tools are necessary to install a belt. The use of a
screwdriver or other tool to pry or stretch a belt may cause
damage to the pulleys and ultimately destroy the new belt.
1. Remove the crank handle.
2. Remove the two hex screws from the top, right side of
the planer.
3. Remove the two, small cross head screws securing the
side panels to the top of the planer.
4. Lift the side panel up out of the slot in the base and
remove the panel from the machine. Notice the grooves
inside the belt.
5. Start the belt on the top pulley (P) with 3 grooves on the
pulley, as shown in Figure 22.
6. Guide the belt between the lower pulley and the height
adjustment screw (Q), as shown in Figure 23.
7. With three grooves engaged on the large pulley, rotate
the pulley clockwise. Keep pressure on the edge of the
belt to keep the grooves engaged on the small pulley.
8. Continue pressure on the side of the belt and rotate
the large pulley while hopping the belt further onto the
pulleys, as shown in Figure 24.
9. All of the belt grooves should be engaged in the final
position and the pulleys should rotate smoothly.
10. Reinstall the side cover and the screws. Do not
overtighten the self-tapping screws.
Mar 03, 2015 | Dewalt DW734 Heavy Duty 12 12" thickness...
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Fits the driver belt of a B&D planer model KW713/715 in a BD713?
Cannot guiarante it but it seesm like it should.
Oct 14, 2014 | Food Processors
Makita planer 2012NB belt replacement
Use dish washing liquid to lubricate the roller and belt on both rollers and place the belt equally on each roller and move in on both rollers evenly
Feb 15, 2013 | Makita 2012NB Electric Planers
I need to change the belt on a Roybi AP-10 planer
I called sears and they actually HELPED
Oct 27, 2009 | Ryobi Masonry Tools
Belt for Powermatic 15" Planer (Planer Model M-0460213)
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Sep 07, 2009 | Powermatic 1791210 Model 15S Deluxe Planer
Ryobie ap 1301 surface planer
Here is the Ryobie support web site . You may still be able to get the manual for your service planer.
https://register.ryobitools.com/customer_session/new
Dec 22, 2008 | Ryobi Thickness Planer Blades
Tools & Hardware - Others Logo
358 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
