I posted a problem. Got a solution. It was on a Mitsubishi 50111 TV. Did the diagnostics and got a code 22 for Short Protect Circuit. Now what do I do? How do I find out if its too expensive to fix? Thanks
  • 167 Answers
Call a good TV Tech and tell him the code.
He should replace Q9A55,ECG85-D9A29,5.6V ZENER-D9A28,ECG519-PC9A21,ECG3098.
This repair should not cost over $175.
Check with your local BBB before you decide on one.
Posted on Jul 30, 2009
Error code 18 on Mitsubishi WS-55311
This is a V20 chassis, circa 2002
Available error codes for this unit are as follows:
12.....No error has occurred
21.....X-Ray protect circuit
22.....Short protect circuit
23.....Horizontal deflection failure
24.....Vertical deflection failure
Jan 07, 2015 | Mitsubishi Televison & Video
MITSUBISHI WT-A42 ERROR CODE 22 "SHORT PROTECT CIRCUIT"
error code 22 is a short protect circuit. this means the tv has found a problem in the tv and will not let it turn on till fixed. this could be several different circuits in the tv that is causing this. we need to test some parts to see what this is. the most common is a shorted convergence circuit. a repair on this would range around 400.00. You should check using a multimeter and also you should be good at soldering
PS:I strongly advice if you don't have experience in electronics then better leave this job to a tech
Feb 17, 2008 | Mitsubishi WT-42313 42" Rear Projection...
I own a Mitsubishi HD 1080 series HD TV; MODEL#VS-50111. Recently the TV shut itself off after a few minutes of operation. I unplugged it and after a few hours, plugged it in and it came on for about 5...
I believe it is going to be a major repair and I would hesitate to invest much money into it. I think the age of this set is older than 5 years. The VS model series were manufactures before the WS model series and they have been around for 8 years or so. Never the less, parts availability is getting tougher. If your pain thresh hold is 300.00 or 400.00
go for it. If not, check out new sets.
Hope this helps,
Sky Assoc
Oct 22, 2009 | Mitsubishi VS-50111 50" Rear Projection...
VS-50705 50" rear projection TV does not
Hi is most robably that you are having a issue with the power supply.
Jun 27, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi 50111
Run the diagnostics.
With the TV power cord plugged in, press the 'INPUT and 'MENU' buttons at the same time -- use the buttons on the front of the TV, NOT the buttons on the remote; a diagnostic Error Code Operational Check will begin, utilizing the 'POWER ON' LED (the green 'POWER ON' indicator light).
There will be a pattern of two sets of flashes, with a pause in bewteen flashes; this sequence of flashes will be repeated a total of five times.
The Error Code designations are listed below:
Error Code Description
12 No eror has occurred.
21 X-Ray Protect circuit.
22 Short Protect circuit.
23 Horizontal Deflection failure.
24 Vertical Deflection failure.
I hope this information helps.
Jun 17, 2009 | Mitsubishi VS-50111 50" Rear Projection...
How to figure out diagnostic code
wat is the code ???
is it Error code 2-3
if so check q5a01 and 03 thrue to q5a06
also replace T5a31 PN/340p216010
Jan 14, 2009 | Mitsubishi VS-50111 50" Rear Projection...
MY T.V. WONT TURN ON
this sounds like your flyback converter is burned out on the circut board....cheap part! but must be done by pro!
Dec 09, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Error code 22 on a Mitsubishi WS-55907 55'' HDTV
your set is the V17 series so a code 22 means short protect. Which means the TV has a short circuit condition and is shutting down to prevent further damage. You can get a manual for the V17 sereis at the following link for 15.99 and they will provide free unlimited support to help you with the diagnosis and locating parts. Your set is coverd in the V17 sereis service manual under the mitsubishi section. Here is the link in case youd like the service manual and free support.
http://servicemanuals.vstore.ca/
Mar 08, 2008 | Mitsubishi WS-55907 55" Rear Projection...
2002 Mitsubishi VS-50111 WIll Not Stay on
FIRST Check for open fuses F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF fuses are open then convergence output circuit would be your problem.
Dec 17, 2007 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi VS-50705, 50 inch Rear projection TV won't turn on!
most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
Dec 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
