Question about Sewing Machines
Baby lock 10 needle embroidery machine.
The circle metal part that holds the bobbin and bobbin case won't turn
  • 98 Answers
Check to make sure that there isn't any thread hung around the hook
Posted on Nov 15, 2017
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
  • 66 Answers
SOURCE: Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
Posted on Jan 28, 2009
  • 69 Answers
SOURCE: bobbin case and threading singer 6423
This machine has a black plastic bobbin case. You drop the bobbin down into the case with the thread coming off in a clockwise direction. If you look close you will see a slot in the bobbin case where there is the metal pieces. The thread will slide into that and as you pull on it it will work its way through and come out on the other end of the metal. Lay the thread over top of the bobbin case and turn the handwheel to pick up the thread. (make sure you close the slide plate)
Posted on Feb 07, 2009
SOURCE: bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Posted on Mar 14, 2009
  • 7 Answers
SOURCE: Problem with spinning bobbin case base of my Pfaff 360 sewing mac
on lockstitch machines with rotary hooks the base[the bit the spoolcase fits in]is held in place by a retaining finger,tip machine back and you will see a long finger with a right angle lug sticking out approx 4/5mm .loosen the screw holding the finger only slightly and spin the base till the top of the base is at the 12.00clock pos.[it will help if you take needle plate off]the lug fits into the cut out of the base.then tighten finger screw and try. if base is jammed you will need a mechanic to dismantle hook and repair and retime the machine.
Posted on Jun 24, 2009
My wife has a Baby Lock Enterprise 10 needle embroidery machine. The automatic threader is not working for any of the needles. Help
This can be a tricky adjustment, Make sure you have the correct needles inserted correctly. The hookwire isn't lined up properly with the needle bars holding the needles. Expensive machine to break trying to fix it. Have a trained professional Take a look at the threader mechanism, you will have the opportunity to learn something about your machine in the process.
Cheers,
Embroidery Services
San Diego, CA
Sep 22, 2017 | Baby Lock Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
Bobbin case bound up with thread and popped out of position
Ensure needle/needle bar is fully up at its highest point, replace the bobbin case with its open end seated at the back, the rotary hook tip should be just underneath it, just check further that it resides nicely along the groove of the rotary hook, re install the needle plate cover and tighten the 2 holding screws so that the bobbin case can be nicely in place, manually and slowly hand wheel the needle down several time to ensure the bobbin case is not unseated/needle is not knocking the bobbin case. Hope this can help/otherwise there are adjustments that need your local technician to do it.
Jan 10, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
Bobbin thread shows on embroidery machine
Did you remember to put down the presser foot?
Nov 13, 2012 | Baby Lock Sewing Machines
I have an Esante ESe2. I am having a problem with the bobbin. I was doing some embroidery and the machine broke a needle in some dense stitching. Now, the machine will sew about 10 stitches and then the...
Since the needle broke, it could have knocked your machine out of time--requiring service.
FIRST, try this: Remove the upper thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Frequently, when the thread "jumps" out of the thread path (or wraps around a guide or the spool), the thread will stitch about an inch and then break. If you watch the upper thread when you are stitching, do you see the thread tightening, tightening, tightening and then Snap?
As far as the bobbin installation, you would need to consult your owner's manual.
Apr 16, 2017 | Baby Lock Esante
I have the basically the same problem. i was sewing and now the thread in the needle will not pick up the bobbin thread. i would appreciate any help. I have changed the needle, bobbin, and thread several...
Check the easy stuff first:
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correctly.
the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly.
the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. If that is the case.
Aug 04, 2009 | Baby Lock Sewing Machines
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Nov 14, 2008 | Baby Lock Esante
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
