Question about Nintendo Wii Console
£ Amp fuse in plug keeps blowing - Nintendo Wii Console
  • 1,525 Answers
Hello you have a dead short in the power supply
shaun
Posted on Jul 31, 2009
  • padstar1975 Nov 08, 2010
    hi i carry this same problem, how to fix this issue or is it better to buy a new power supply??? how to test this is the actual problem?
2004 pt cruiser keeps blowing fuel pump fuse,replaced fuel pump, no change.runs rough at idle and stalls,blows fp fuse,also replaced ign.coil,plug wires and plugs also changed relays
There are two fuses for the fuel pump relay. One fuse is load side of relay, that fuse also sends voltage to load side of asd relay, the asd relay sends voltage to several systems, two of which are the fuel injectors and ignition coil. I'm not telling you to replace, anything, but, you need to do some testing.
The other fuse goes to control side of relay, smaller amp fuse. I don't know the amp rating of the fuse that keeps blowing.
See that fuse, it supplies voltage to load side of fuel pump relay and also to asd relay.
Oct 22, 2016 | 2004 Chrysler PT Cruiser
NO turn signal or neutral light, no speedometer or horn working. Changed 10 amp fuses but they keep blowing?
10 amp fuse is small a few things that you can do. go to a 15 and turn every thing on snd see if it blows and how long. if it don't blow in 5 mins. your good if it does blow then you have a wire problem. if so. unplug every thing that has to do with that fuse. and plug 1 in at a time UNTIL the fuse blows. good luck.
May 03, 2016 | 1999 Yamaha V Star 1100 Custom
Why does it blow controller fuse when key is turned on?
Electrical: Circuits, Relays - SwedishBricks
www.swedishbricks.net/700900FAQ/Electrical-CircuitsRelays1.html
fuse keeps blowing Drills & Drill/Drivers Questions ... - Fixyawww.fixya.com > Forum > Tags > fuse keeps blowingDrills & Drill/Drivers fuse keeps blowing questions and answers. Ask your fusekeeps blowing drill and drill/driver questions. Get free help, advice & support for ...Ryobi Multi-Volt Battery Charger Fuse - Questions - Fixyawww.fixya.com > ... > Ryobi > Ryobi Multi-Volt Battery Charger1423701) and have blown the internal fuse. The label on the charger indicates the input is 120V AC. Question about Drills & Drill/Drivers. 1 Answer ...Remember that fuses can fail without showing signs of an obvious ... remember that suspect turn signal flashers, fuses, bulbs and relays can be ... will be predictable, such as a bad current or ground connection, blown fuse and the like. .... The relay then sends power to all the lock motors (all doors except driver's door).Missing: drills
[PDF]Electrical Safety - Occupational Safety and Health ...
https://www.osha.gov/.../4...
Occupational Safety and Health AdministrationShe has an older drill with a steel housing and a 3-prong plug. ... current. This willgenerally allow enough current to flow so that a fuse will blow or a circuit breaker is tripped, thus turning off the electricity in that circuit. ..... There are three major ways tocontrol power line hazards: 1. ... Install warning signs at driver's eye level.Missing: drills ‎key
Jan 07, 2016 | Drills
My 2008 suzuki grand vitara keeps blowing the fuses for the ACC outlets. both are 15AMP, but even with nothing plugged in, nothing down in the outlets and even with larger AMP fuses, they keep blowin
If you use too large a fuse, the wiring can catch on fire, and the whole car could burn up. You'll need an auto electrician to trace that problem. You can remove any bulb and unplug any device that is on the Acc(essories?) circuit; then see if a fuse will stay; start replacing items till you blow the fuse. It seems like a dead short which can surely melt wires if you keep taking chances. good luck.
Feb 14, 2015 | 2008 Suzuki Grand Vitara
Why does my Definitive Pro Sub 1000 keep blowing fuses the second I put them in?
Sounds like the amp is shoot.
Never power on the amp without speaker connected.
May 24, 2014 | Definitive Audio Players & Recorders
Yes my fuse for my wipers keeps blowing and my wipers turn on when i plug fuse in even know the wipers are turned off.
The power distribution box in the engine compartment # 6 , 30 amp mini - fuse , front wiper motor , front wiper relay , front washer pump , FEM ( also # 7 , 25 amp mini - fuse , rear wiper etc. ) The owners manual shows to disconnect your battery cables before servicing anything in the PD BOX
your relay could be shorted which makes the fuse keep blowing
Sep 05, 2011 | 2001 Ford Windstar
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
3 amp fuse in sat nav power lead keeps blowing
possibly a spike through the ciggarette lighter plug, try putting slightly larger fuse in ( 4 or 5 amp )
temporarily and see if it blows the slightlty larger fuse. if it does it's more likely to be something wrong with the ciggarette lighter socket if it doesn't blow the fuse it's more likely to be the power supply. Ebay for another one perhaps ??
Apr 13, 2009 | LG GPS
Heater/blower died
When you find the fuse if it has blown also check the resistor to control the fan speed. I cant remember if the 1 series has a load resistor multi tap but it may have failed if you use 1 or 2 speed on the fan a lot, max will bypass the load resistor where as 1 will use maximum load and the thermal fuse might have blown. But replace it as caution. In the earlier models it had a block which was nicknamed the hedgehog, a load resistor buried under passenger foot-well up toward the centre, loads of spiky aluminum pegs which cold air blew over to cool it, always packing up in the earlier models £25 from scrap dealer cheap fix compared to the £££££££ BMW dealers rip off. Heater or air con would either not work or blow erratically. Hope this helps
Nov 23, 2008 | 2005 BMW 1 Series
Nintendo Wii Console Logo
250 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
