Question about Optics
Compass and hairline out of place - Optics
    Sniper:
  • 73 Answers
If these are out of place then you need to have them repaired. It's not something you can do at home.
Posted on Jul 31, 2009
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous Vous
My compass doesn't point north, what is the reason?
The reason why your compass doesn't point to the north anymore is because the compass has been exposed to articles with iron content, like the compass being placed next to a pair of scissors or a knife, microwaves, and high tension wires.
Sep 03, 2012 | Acr Electronics Camping, Backpacking &...
I need a new compass for tasco 322 BCW waterproof binoculars. Any ideas where I can find one?
Open the battery door, clean all inside with Alcohol & Q-tip. Check that the AG10 or 389 batteries are positive up. Now the compass dial pivots on a shaft. It seems to get caught. Take a strong magnet and rotate it above the compass lying horizontal and spin it until it spins freely. Take it away slowly. Does the compass settle down to accurate heading? If so place back in the top of the model 322BCW observing the glued in marks on the clear window area. Re-screw in, press brass button red LED should light.. If NOT recheck for corrosion. Regards, Don
Jul 03, 2012 | Tasco Optics
The letter C is flasing in my dash board
The flashing "C" in the Instrument cluster if for the Compass. Here's the bulletine...
Subject: Compass Displays a Steady or Flashing "C" In Place Of Directional Heading
Models: 2008 Saturn VUE built on or after 11/09/2007
This PI was superseded to update Recommendation/Instructions. Please discard PIT4699.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: The compass displays a steady or flashing "C" in place of directional heading.
To return to a normal heading display, press and hold the cluster stem for approximately 2 Seconds.
The displayed heading is not correct after driving for 30 seconds, use the following "Compass Calibration" routine.
Press cluster stem until the Season Odometer is displayed (Not Trip A or B).
Press and hold cluster Stem until the solid "C" is displayed. To the right of the "C" will be the "Zone". Refer to the variation zone map above for the correct setting. Turn the stem Right to increase, Left to decrease. It will take a few seconds for a change of zone to be updated in the display.
Once the Zone is correct, press the Stem to display the Flashing "C". Do not touch the Stem again until the direction is learned. Drive the vehicle in slow circles in an open area until you see a compass (oc tant) heading replace the flashing C.
Note: Vehicles built prior to 11/09/2007 were not built with a compass.
Recommendation/Instructions:
Engineering is aware of this condition and is in the process of root causing. It is known that the Remote Compass Module (RCM), Body Control Module (BCM) and Cluster hardware are not at fault, and these parts should not be replaced.
Reinforce with the PDI technicians that the Compass Zone and calibration is still required as part of PDI.
Hope helps (remember to rate and comment this answer).
Mar 07, 2011 | 2008 Saturn VUE
The letter "C" is flashing on the speedometer
Feb 11, 2011 | 2008 Saturn VUE
How do you reset the compass??
  1. Stop the vehicle and place it in "Park."
  2. Press and hold the "Set" button on the compass for about two seconds. The button is located directly below the compass to the right.
  3. Press the "E/M" button repeatedly until the correct zone is displayed. If you do not know your zone, you might have to contact your dealer for this information.
  4. Press and hold the "Set" button for about two seconds until the display flashes, indicating that the compass is reset.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 22, 2010 | Toyota Land Cruiser Cars & Trucks
The orginal compass was deleted.
Tom Tom changed the software (one of the upgrades you get through Tom Tom HOME) to remove most of the compass functions but the manual still refers to setting it up so it appears as a menu item when you first operate the unit but then subsequently disappears if you update the unit software as it did on mine.
It is talked about in some of the Satnav forums but there don't appear to be any solutions.
Sorry that is not much help.
Peter
Mar 05, 2009 | Tomtom ONE 3rd Edition GPS
1997 Nissan Terrano electronic compass blinking
CORRECTION FUNCTIONS OF COMPASS
NAEL0307S01
The direction display is equipped with automatic correction function.
If the direction is not shown correctly, carry out initial correction.
INITIAL CORRECTION PROCEDURE FOR COMPASS
NAEL0307S02
1. Pushing the “Mode” switch for about 10 seconds will enter the
initial correction mode. The direction bar starts blinking.
2. Turn the vehicle slowly in an open, safe place. The initial correction
is completed in one or two turns.
NOTE:
In places where the terrestrial magnetism is extremely disturbed,
the initial correction may start automatically
Feb 08, 2009 | 1997 Nissan Pathfinder
Tasco OS36 Binoculars battery replacement
The screw you removed holds the battery cover in place. The cover is roughly rectangular with rounded corners. Once the screw is out, gently insert a sharp blade into the hairline crack between the cover and the binocular body and pry the cover off. The two watch batteries will be obvious.
Dec 03, 2007 | Nikon Travelite V Binoculars
Optics Logo
50 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
