The part that you screw is on the male end of the hose
IF it is not as described you will have to check with a dealer
by looking at the male fitting you will see that it is blocked off with a small pin out of the center
this is a non flow valve that closes of the hose to stop the oil from running out and to stop dirt from getting in
there is a similar operation in the female connection and when pressed together one opens the other to allow oil flow
when pressed together you slide the screw bit up to the thread on the female bit and do it up
quick connect hose fittings are universal in construction and used universally across all manufacturers and hose manufacturers
Removal & Installation
NOTE
There is a trend among manufacturers today to refer to the source of belt-driven electrical power as a -generator-; however, by virtue of the method in which the -generator- produces electrical current the device is actually an -alternator-. The two terms may be used interchangeably.
Image 89612G12l Not Found
