Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome 10000 Stuck on Bobbin Winding Screen
I just purchased a used MC 10000 and was told it was in perfect working order. When I turn it on it is stuck on the Bobbin Winding screen and won't do anything else. The bobbin winder is in the far left position so it is most definitely a computer problem. Help!
SOURCE: bobbin wont spin
I had the same problem last night but was able to solved it by flipping the plastic bobbin over and re-seating it on the post. This time it clicked in and I was then able to get the post to spin. Good Luck!
Posted on Jan 13, 2008
SOURCE: Bobbin Winder won't release
i have a husqvarna rose, i has the same problem when i started using my machine. i was suggested to not wind the bobbin so fast. the reason it gets stuck is because the thread is so tight on the bobbin it actually makes the bobbin a tiny bit smaller, making it hard to get off again. if you dont wind it so fast, it doesn't get so tight.
kylee
Posted on Mar 25, 2008
SOURCE: Janome sewing machine bobbin winder
I had that problem the first time I tried to wind a bobbin. What a mess. The next time I let the thread run through my finger and thumb before reaching the bobbin. I had to do the same on a previous Kenmore.
I've also found that the heavier Bernina bobbins don't 'jump' around.
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
  • 16 Answers
SOURCE: Bobbin winder shaft won't spin. LCD says bobbin winding.
I had the same problem. The trick is to make sure that when you put the bobbin on the winder that the notch on the bobbin clicks on the notch holder. So turn the bobbin on the winder until you hear a click or that the bobbin can not be turned. To check if the bobbin is on the holder correctly start the bobbin winder without thread. If the bobbin is engaged on the winder it will spin, if not then it is not set on the notch. I hope this helps.
Posted on Jul 07, 2009
New janome MC350 screen stuck on bobbin winding cant do anything with programe
I know this sounds silly but have you made sure the bobbin spindle has been pushed back when you have finished filling the bobbin. Switch of all power, and try again.
Aug 24, 2017 | Janome Sewing Machines
Need jsmc850 disc
you might try janome customer service about where to get a
disc
Aug 03, 2012 | Janome Memory Craft 10000
How to transferpatterns from my computer to my janome 1000
Use this link to contact and request your manual for the Janome MC 10000
Nov 04, 2011 | Janome Memory Craft 10000
I have a Janome 10000 and I am trying to wind some bobbins so i can get started on a project, however the winder is winding the thread very loosely and I know it will just knot up if I try to use it that...
Double check the threading of the machine when winding the bobbin. Or as a last hope measure when winding tensiojn the thread thru you fingers just before its at the winder.
Derek
Jan 17, 2011 | Janome Memory Craft 10000
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
Display will only show "Bobbin Winding"
Presumably you have turned the machine off, and then back on again to, in effect, reboot the machine's computer?
The only other suggestion I can think of, is to ensure that the bobbin winding post is FULLY to the left when you want to sew.
It may be worth looking around the bottom of the winding post to see if there is any build-up of thread (or other stuff) that is preventing the post going to the fully-left position.
Apr 09, 2009 | Janome Memory Craft 9000 Computerized...
Reading Janome design cards with MC 10000
Please sent email mamyan@in.com. And we can solve you problem, There is any words i don't understand. If it will be understandly, I can help you. skype - serari55 - my nicke.
Oct 06, 2008 | Janome Memory Craft 10000
MC 10000 Digitizer 10000 Error Message
Try downloading the updates for your software from Janome Global, downloads, software. Version 1 needs patches to make it compatible with XP. The most current Version for the 10000 software is 2.21, and the upgraded program is Digitiser pro/MB , a much more stable and far easier version to work with. The upgrade has to be purchased via a dealer or direct from Janome.
Apr 16, 2008 | Janome Memory Craft 10000
Bobin winding and slow pace on project
The speed could be if the satin stiches are to wide, than the machine reduce speed to get a good result.
How is the speed of the embroidery when it does fill stitch (small stitches)?
Not shure about the bobbin winder, but to check this its nessesarry to get inside the machine.
Feb 13, 2008 | Janome Memory Craft 10000
Janome Memory Craft 9000 Computerized Sewing Machine Logo
188 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
