Question about Weber Spirit? E-310 Propane Grill
Burners light but don't give off much of a flame. grill is 3 years old...burners arent corroded or anything...
  • 67 Answers
Is your regulator OK? sounds like not enough gas pressure getting to the burners.
Posted on Jul 30, 2009
I have a brand new Weber 670S and put it together....the ignition will fire and I get a 6 inch flame, but the burners don't light....and the flame goes out when I release the knob...
Since the main burners and the rear infrared burner (if so equipped) comes already installed, I don't think your assembling it is the problem. It's probably the grill's gas regulator that is giving you the problem. That's assuming you are following the manual's instructions on how to light the burners, the first time. For now, Ill assume you did. If you open the gas tank valve to fast, it shoots high pressure to the regulator & locks it up.
So, to solve the problem, follow the directions below:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly (It's 's not under warranty). It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! And thanks for choosing FixYa.
Aug 26, 2011 | Weber Summit S-670 Gas Grill
My weber grill (silver) does not get very hot after I open the top to do anything on the grill. What is the problem and how do I fix it? Dave Hendron
First, consider how long you preheat the grill and to what temperature are you preheating? If it's not long enough to reach at least 350 degrees, before you open the hood to start grilling. You're not allowing the grill to preheat long enough.
Second: Have you looked at the flame height on each burner when they're turned to the highest setting? It may be that the burners need to be removed and properly cleaned. In addition, the venturi valve on each burner may be partially clogged with spiders or spider webs. When that happens, the burners do get the right air to gas mixture/ratio and the burners don't fully light and heat up.
If the burner flames remain lower than they should, the grills regulator may be locked up. In which case, turn the tank valve OFF, disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner farthest from the tank first and turn it to high. Does the flame height now, appear to be normal? If so, light the remaining burner(s) the same way. The flame height on all should be the same on the highest setting. If they don't you'll need to replace the grills regulator/hose assembly. You can purchase one at just about any home center or hardware store that sells grills and grill accessories. Just take your old one with you for comparison purposes.
Any or all of the above should solve your problem. Please let me know and if you have any questions, don't fail to ask.
Apr 15, 2011 | Weber Genesis Silver B Grill
I have a stainless steel Kenmore propane grill, model 119.16311800. It has four burners and a side burner on the left. It is two years old and has performed perfectly for two years. I am now having...
With all the you described, your best bet is to replace the grill hose/regulator assembly. It's not expensive and it's not difficult to do. You can find the hose/regulator assembly at any home center or hardware store that sells gas grills. The assembly is universal, but take your old one with you for comparison purposes.
As far as replacing the burners are concerned, that's not difficult either. And you may be able to find the replacement burners at www.sureheat.com , as they made the Kenmore grills for Sears. And yes, the scenario you gave for removing the burners is correct.
Hope this helped you and you will be kind enough to give my response to you, a positive rating.
Happy Grilling!
Mar 26, 2011 | Kenmore Grilling
I have a fire Magic A660 drop in grill (natural gas) and when I light the burner (2 of the 3 burners) the flame doesn't travel all the way around the burner. Gas is coming out of all the ports. I can light...
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Mar 18, 2011 | Fire Magic Grilling
I have a 3 burner spirit grill. I can light the grill, but only burner 3 gives me a nice even line of blue flame. Burner 2 seems to be the worst with oranges flames on the right and left end. Burner 1...
Charcoal and grease build up can restrict even the best gas burners , my suggestion is to clean your gas burners with a burner tip tool . You can purchase these at Lowes or Menards . Here is a website for you to visit to get the ideal . http://www.metaltech.com.sa/victor/tips.htm
Goodluck
Electrician by Trade
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
The first burner seems to burn very low and not very hot
If it was me, I would,first try to clean them and see if that improves the flames. During the course of cleaning you can determine if the burners are corroded and needing replacement or just caked up and dirty. Are the burners stainless steel or cast iron? Cast iron lasts longer, and tends to get smaller in flames when it's seams corrode shut. Plus it is easier to clean. Stainless steel tends to corrode and fall apart, causing flare ups and unsafe use. Douglas
Jul 05, 2010 | Barbeques Galore Turbo STS 4-Burner...
My grill lights, but won't really heat up. I
try cleaning the burner and the orffice , check reg is giving right pressure
May 10, 2010 | Thermos Gas Grill 4617222
Low flame
The newer type tank has an anti tip safety device. It gets all boo boo'd when the grill is moved around. Remove the tank. Open the valves on the grill and close them back. Re install the tank and slowly open the valve.
Jun 27, 2009 | Brinkmann ProSeries 810-6330-W Grill
Weber Spirit? E-310  Propane Grill Logo
189 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
