Question about Lexmark T632 Laser Printer
Problem with ink coming out on paper
I have just refilled my black ink cartridge in a shop and come home and tried to print but the ink is very faint on the paper I am printing on, what's the problem?
  • 65 Answers
Replace the toner cartridge with a brand new one. There's no such thing as refilling toner cartridges. When it's empty, the drum unit is finished and it should be replaced, not refilled. Remember that the drum unit is sensitive to light, and will also be damaged if exposed to a great amount of light over a perid.
If a new cartridge does not solve your problem, remove the cartridge and check out the charge roller. It's located in the upper part of the "cartridge-room". It's a grey roller. lower the front cover the get easy access to it.
If it looks nice and clean, just leave it. If it is dirty and smutsy, you should remove it and try to clean it with hot water. If it is damaged in any way, it should be replaced.
Still problems ?
Check out the fixing unit. Remove the fixing unit and look at the the big rollers that put out the paper. If they look nice, put the fixing unit back in. If they are burned and dirty, replace the fixing unit.
Good Luck.
Posted on Jul 29, 2009
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
I refilled the cartridge, it worked for a week. Then it abruptly began to print very poorly. Faint, with horizontal lines. I filled the cartridge again. No change. I cleaned the head and now it prints...
The problem that you have is that the ink that you use
in old/bad quility or you have air bubbles in the sponge
of the cartridge and that block the ink
in order to have a success refilling check the video
this is a simple method
with no special tools and machines
Mar 29, 2011 | Office Equipment & Supplies
The printer suddenly started printing fuzzy text. I think it is out of alignment but when I try to print the alignment page, it comes out fuzzy too. Is there another way to align the printer and take care...
There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective
raaj_k001@rediffmail.com
Jan 13, 2011 | HP PSC 1410 All-In-One InkJet Printer
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Hi friend, I refilled the black ink into the
i've quite come across this kind of problems many times. Simply replace your cartridge with new ones or try that old one to dip its head in the hot water for sometime.
Dec 09, 2009 | HP Officejet 6500 Wireless All-in-One...
I have a hp deskjet 3320 printer and i refilled the black and colored ink and it still prints the words out mulitcolored like it is running out when i want it to print out in black
Sounds like your black cartridge has a clogged print head. If you bought a refill from a store or on-line you should take it back and either have them clean it (if they know how) or return it. If you refilled this yourself at home this is a problem that occurs when you let your cartridge dry out before you refill it. You can try and rehydrate the print head by placing it on a warm moist paper towel until you see ink soaking into the towel (ink stains most surfaces so be careful where you do this). Otherwise, I recommend Cartridge World for refills because they go through cleaning and print testing steps to make sure this doesn't happen.
Oct 20, 2009 | HP DeskJet 3320 InkJet Printer
Ink cartridge question
Try Soaking the print head in Warm water for about 3 minutes. Dry off the print head with a paper towel. If you don't see any ink on the paper towel, then the print head is clogged and it will be difficult to unclog the cartridge.
If the warm water doesnt work, then next try some Windex with amonia. Only soak the bottom of the cartridge where the ink comes out. Soak the printhead for about 3 minutes, and then try wiping off the bottom again. Press a dry paper towel on the bottom. If there is no ink then it is probably time to get a new cartridge. In the future, always try to refill your cartridge right away as soon as possible so that the ink in the cartridge/print head doesnt get a chance to dry out.
I hope this helped.
Please leave a rating if I have helped you with your question/problem.
Have a good day and good luck.
Mac =)
May 20, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Jan 15, 2008 | Lexmark X75 All-In-One InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Lexmark T632 Laser Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
