Question about Science & Laboratory
Schott KL 1500LCD displays error err2
Hello thanks for helping me.
At first, the main fuse blew every time i tried to turn the device on, i found diode bzw063b shorted, i replaced it and now the device can turn on but the message ''err2'' appears in the LCD, the fan works and IC u2009b gets too hot, i couldn't find that IC here in mexico city so i couln't replace it.
According to the manual that error is about overheating, but nothing apart that IC is hot, if anybody can help me finding that IC i'll be very greatful.
Any ideas?
Thank you very much
  • 236 Answers
SOURCE: STRS6707 problem
In the past, my experience with Sonys is that you need to use Sony parts to successfully repair them. Also you might have a cold solder joint which creates an arc when you turn it on. This arc will cause a "spike" which could possibly take out the regulator. Stargazer
Posted on Jan 21, 2007
  • 10 Answers
SOURCE: Error Message
normally flicking the transportation lock on the scanner open and locked a few times and leaving it in the open position works.
also you can download a better version of scan software, mine works fine now.
TWAIN Driver and EPSON Scan Utility v3.04A
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14082&prodoid=24875245&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=25&y=8
Posted on Nov 30, 2007
SOURCE: overheating
mine was doing the same thing....i think you will find 9 times out of 10 the thermal paste has dried up.....i looked on google and it took me step by step through the process....im a total novice and it was really easy..will see if i can find the link for you.....Tina xx
Posted on Apr 27, 2008
  • 158 Answers
SOURCE: Power IC Damaged Displayed
if it displays "power IC damaged ,your CD player is as good as DEAD.
For giving it a new life ,take it to PIONEER SERVICE and get the IC replaced and any other repairs that may be needed.
Posted on Jul 25, 2008
Ecollier2012
  • 3459 Answers
SOURCE: dptv335 Philips 55PW9363
Did you ever get this set fixed? If so what was the solution?
Posted on Oct 24, 2008
How do I fix my yamaha receiver? I turned it up and it shut off,tried to turn on heard fuse blow. Replace one of the two fuses 10A 125v that one blew also.
Fuses blow due to an overload. What has happened in you case is one or more of the output devices (found on the big heat sink) has shorted and acting like it was a piece of wire. Now you have to find out which. By the way it might have gone due to bad speaker wires or speakers, or speaker wires touching each other.
Jan 11, 2016 | Yamaha HTR-5890 Receiver
What does PSTD stand for on the remote?
Washing Machine ' FAQ ' Help & Troubleshootings ' Haier ZA
www.haier.com/za/help_and.../faq/washing_machine/
HaierQuestion : Error Code-control panel display "Err2" · Question : Error Code-control panel display "Err5" · Question : The door lock light flashes 8 times and stops .
Oct 29, 2015 | Haier Televison & Video
Schott ceran touch
might be transformer noise? try turning the cooktop circuit off at the electrical main switchboard.
or get your wife to stop singing opera!!
Oct 22, 2013 | Kuppersbusch Cooktops
Schott ceran cooktop glass replacement
Hi, cooktop glass replacement can be found at amazon, here: Amazon com Schott ceran glass take a look. Wish you best of luck
Mar 31, 2012 | Belling Ovens
Stove wont do anyhing but beep every other minute
Sorry to read about your problem, I hope this helps you out.
try to reset, by turning off and on your circuit breaker, if that does not help, you have a defective main control card. contact http://mieleusa.com/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Miele 30 in. KM443 Electric Cooktop
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
Fuse blown repeatedly on CB553H-KL
Re your post/description on an LG CB553H-KL fuse blowing, this is indicative of an over current (>5Amps) flowing through the AC mains supply. If you are comfortable doing component level repair and familiar with electronic parts/circuitry, continuity tester and a soldering iron, please do passive (off-board) test of the following components:
D900 - bridge diode;
C908 (150uF/400V) - filter/power capacitor;
Q901 - regulator.
If Q 901 is shorted, pls likewise check ZD901, D910, R902 & 915.
Just to be sure/safe, check also:
C901, 902 & 904;
TH 901 & 902;
Though unlikely, you may want to check also:
Q706 - Horizontal out transistor (attached to the aluminum wall acting as heatsink;
FBT - Flyback transformer.
Other than the component aforementioned, no other parts would cause enough current flow to blow the fuse. But of course, anything can still be wrong
Hope this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | Compaq FS 7550 17" CRT Monitor
Blowing Fuses
main rectifier could be shorted, main regulator could be shorted MOV surge supressor is probably shorted. MOV will be a little disc close to the power cord input (after fuse).
Jul 31, 2007 | Sony KV-32FS13 TV
Science & Laboratory Logo
199 people viewed this question
Top Science & Laboratory Experts
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
