2001 Pontiac Bonneville Logo
m
mike powless Posted on Nov 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 pontiac bonneville sse super charge engian what typ of gas to put in
Bill Boyd
Level 3:
Top Expert:
  • Pontiac Master 53,816 Answers
  • Posted on Nov 13, 2017
Bill Boyd
Pontiac Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11945002
Points
172802
The higher the compression ratio the higher the octane rating required
normal compression ratio 10 or 11:1 will run on 91 or 95 octane rating
higher will require 100-110 octane rating or aircraft engine gas
superchargers only increase the amount of air available for combustion
it is the compression ratio that determines the octane rating required
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Nov 04, 2008
SOURCE: fuse box
CHeck the owners manual index or the back side of the fuse box cover place they are usually in both locations. If neither are available you can order a owners manual on line or with the local dealer. The parts store should have a repair manual for your car also with this information
Anonymous
  • 3533 Answers
  • Posted on Jan 06, 2009
SOURCE: Pontiac radio codes
recommend a dealership or a place that installs radios that has access to these codes
milespeed
  • 599 Answers
  • Posted on Jan 14, 2009
SOURCE: how do i remove the
ignition? tilt column?... steering wheel puller..lock plate remover....hazard pin puller.. down til you remove collar for ignition.. key in acc use pin the remove lock cylinder and key assembly.reverse
Anonymous
  • 1118 Answers
  • Posted on Jan 19, 2009
SOURCE: I threw the belt on a 3800 in a 1995 pontiac bonneville SSE.
its best to go on line to a major auto parts store, and get a diagram for this. thats the best way.
Anonymous
  • 1990 Answers
  • Posted on Feb 04, 2009
SOURCE: serpentine belt for 1997 pontiac bonneville sse w/ supercharger
http://www.mvreader.com/multiview/dayco/catalogSearch.php?autoCatalogSearch=1&make=PONTIAC&model=BONNEVILLE&year=1997&year_from=&year_to=&engine=All&l=n
This should help. Please Rate My Response! Thanks!
1helpful
How do i remove my 3800 from 1999 Pontiac Bonneville
Hey Carlton, you can find most of what your looking for at autozone library its all free and no spam but your first choise should be to go buy an auto repair manual for 20.00 its all very well spent and you'll have a great reference materal .
1995 Bonneville: i have 1995 pontiac bonneville fuel all the way to...
have 1995 pontiac bonniville sse fuel all the way to injectors will run if you put fuel into intake then starts and runs till fuel runs out. I have replaced fuel pump and fuel pump filter,cam postion sensor and coil paks
1helpful
1992 bonneville sse w/ac replaced blower motor +
You replaced the blower control module or the blower control panel on the dash? This has automatic temp control right?
1helpful
Dead Battery on a 2001 Bonneville SSE
Under the back seat. The seat just pops out.
I have a 1994 Pontiac Bonneville SSE.. won't start
It sounds like you have a short somewhere that is draining the battery...this type of thing is usually caused by a faulty voltage regulator. I recommend taking the alternator to an autoparts store to have it tested...don't be surprised if the alternator tests good; a faulty voltage regulator can and will drain a battery in a matter of hours. I am including a link where you can order a voltage regulator for your Bonneville or, while you are at the autoparts store, you can buy one there. The link will help you to see what the voltage regulator looks like so you can identify it in your engine compartment. Hope this helps, good luck!
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
