Question about Blaupunkt Car Audio & Video
Radio just plays out static cant get a station and aerial is connected
    Problem Solver:
  • 13 Answers
Check if tuner is not to 'local'
Posted on Jul 29, 2009
Why is there radio static all stations Hyundai Elantra
Sounds like you have damaged the FM aerial which is located as a copper film on the inside of the back window where the heater element is. There are connectors too. Children and dogs damage them.
Feb 26, 2016 | Hyundai Cars & Trucks
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
Dec 10, 2014 | Audio Players & Recorders
I cannot get the AM radio stations to play or the CDs to play on the AIWA XR-M10. FM stations come in fine.
as for the am radio you need to connect the am aerial to pick up am frequencies as for the cd player need a bit more info on that
Oct 14, 2010 | Aiwa XR-M10 Shelf System
Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
Could be a bad connection in between radio and antenna . Check that first . If that doesn't work try a film strip antenna
Jul 24, 2009 | Sony CDX-GT310 CD Player
Cant tune radio
IS YOUR AERIAL CONNECTOR CONNECTED
Apr 05, 2009 | 2004 Ford Focus
Bose wave radio static only
Try replacing the battery (turn it over, have a look on the bottom there will be a door for a battery) and then trying it. Alternatively connect a aerial as it sounds like a reception problem.
Jun 01, 2008 | Bose Wave Radio II
Can't heat radio
Hi There Laura,
For you to get radio reception then you will need an aerial...
The FM stations are very weak and thus need a good long aerial to collect these weak signals.
Some receivers need the aerial to be a "loop" so and on the rear of the receiver there will be a special two port aerial connector for the FM..
You dont say where you are but if you are in the "outback' then a good long aerial will be needed...
The same can be said for the AM radio signals these are much lower in frequency but still need an aerial.
There is a difference with the AM signals as they also need a good earth as follows.
On the back of the receiver there will be an aerial connector marked AM and it will show an earth connector and and aerial connector.
There needs to be a good earth connected to the earth connection and another long wire connected to the aerial connector.
The earth should be a metal spike about 500mm long driven into the soil outside in the garden
and connected to a wire which comes inside thru the window to the earth connector on the rear of the receiver.
The aerial wire must not be connected to earth at all, but insulated.....
this wire connects to the AM connector out thru the window and up to the nearest high point. Like a tree or a pole...NOT A POWER POLE as that dangerous.
When you connect to the tree use a piece of plastic rope or something to insulate the wire from what ever it touches, as the radio signals are not allowed to come in contact withthe earth until they get inside the receiver...
You can use a wire with a plastic cover on it if you like..
You may wish to ask your neighbour if you can look at his aerial connections and learn how its done...
He wont mind.... unless you are "outback" and the nearest neighbour is 100miles away..
That makes it more difficult.
If you get stuck ask here again and I'll pass on more detail for you..
Cheers for now
From YUBEUT..
Apr 29, 2008 | Durabrand W600 Shelf System
Car Audio & Video Logo
55 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
