Karen Higgins Posted on Nov 13, 2017
How to enable the alarm on a sangean wr2 with no set button manufactured july 2014
1helpful
My 2014 Elantra's remote for alarm dosn't cherp or light up when pushing the button on remote to set the alarm. But the doors will lock. why?
The chirp comes from the alarm system itself. it may be a electrical short in the alarm system, or a damage in the alarm itself. u need an alarm shop or a good tech. wish I was there.
1helpful
When the alarm activates on my Sangean WFR-28, I can see the preset station showing up on the screen but there is no sound, although the volume is set to 20.
I have the same issue with my Sangean WFR-28c. I just contacted support (through Sangean Europe site) but im still wating for an answer. If this carries on, i cannot use this radio. :(
How to enable alarm on sangean wr-2 clear
It's tricky but it can be done.. I should add that it'll require some patience but it'll happen. First thing is hit reset on the bottom of radio. Second thing is to interrupt the RDS (scrolling message after reset) by hitting the power button. Now long press set until it begins to flash 12:00. COUNT the flashes until the 26TH flash and hit BAND. It doesn't always work, but you'll know it does when the word alarm, an alarm clock symbol, and a speaker symbol are on the display above the time. I should also mention that it helps to switch the antenna (external & internal switch on the back) a few times (3 at least, 5 most) during both the RDS scrolling after reset AND while counting the flashes. They (Sangean) disabled the alarm, but some determined soul figured this out and it's been passed on by word of mouth through inmates. Good Luck. It's been my alarm clock on the streets here for 3 years now.
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
3helpful
I have the ATS909 - a wonderful set. But how do I turn off the alarms? Thanks [email protected]
Press a timer button and then press C for Clear. To reset, press a timer button and then Enter. Ringbearers
1helpful
Sangean PR-D3L - How do I change between 12 and 24
Archer, I have read the entire PR-3DL manual and there appears no mention of a 12/24 hr setting, unlike certain other Sangean radios. The instructions for setting the alarm do not mention 'a.m.' or 'p.m.' .
Apparently, the clock is a 24:XX:XX display only.
Top Sangean Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
k24674
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
