Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
Port forwarding I am unable to use the bit torrent client on my system. Want to try port forwarding to help. How do I forward a the ports 6881-6889 ? Or is there any alternative to get the torrents running on my system?
  • 54 Answers
Www.portforward.com
Posted on Nov 24, 2007
Forwarding ports
Port Forwarding is explained indeepth by the torrent companies help FAQs section,
Heres a link that may helps you too....
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
In the Admin function you can accept the ports if you have the correct servers address's
You must add them to your firewalls permission settings and then try the test again,
Note ,
Even with Port Forwarding set up,
you will also require the correct band width and downloader from the torrent site,
ie,
Bit Comet and Bitcomet Excelerator
The downloader and the high speed function,together.
Hope this helps,Misterdj
May 03, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Internet ip slowing downloads it only does this on one site (for now) i contacted the site and they said it was my ip well at first i can have the download at about 200Kb/s then it drops low any...
Are you on about bit torrent downloads?
What torrent client are you using?
Have you configured it correctly?
Have you made sure you are NOT using port 8081?
If using a router have you forwarded your port correctly?
Who is you ISP?
Have you checked you connection with speedtest.net?
Although not necessary it would help to know which site ( I understand if you don't want to mention it).
More info may get you an answer. (I could help as I've been using a bit torrent client for over 8 years!)
Jul 18, 2009 | Apple MacBook Air
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
Port forwarding for belkin router
You need to open the port for Bit torrent this link will help you to do that http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/BitTorrent.htm
Hope that he;ps............
Sep 17, 2008 | Belkin (F5D7230-4) Router (587009)
Port Forwarding
Try here:
Aug 11, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Utorrent. the port problem had been solved. but the connection is still yellow
please check if the port allocated for u-torrent is port-forwarded properly..also check you have assinged a unique port number for u-torrent program..go to options tab in u-torrent and speed guide options in it and check the assinged port number!..or u can visit www.port-forward.com to port forward for the u-torrent!..thank you !!..
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
Port forwarding
hi there,
this is a basic step used to forward ports to your system.
Port Forwarding Steps for Routers 1. Log into your router. Usually the URL is http://192.168.1.1/, and enter the username , and the password . If you have never set a password, the password (which you should change) is admin. Consult the manual if you have never set up your router before or need to reset the password. 2. Click on the "Applications & Gaming" tab or Under Advanced, click Port Forwarding.
3. Click on the "Port Range Forward" tab .
4. In the "application" field, type "web" (if you are forwarding wb traffic on port 80) or "torrent" (if you are forwarding bittorrent traffic on port 40156). This is just a "nickname" so that you can recognize what you were trying to do when you come back to it.
5. In the "Start" field, enter: 80
6. In the "End" field, also enter: 80
7. Set "Protocol" to TCP. Web and Bittorrent servers use only TCP, so there's no reason fo forward UDP traffic too and create an unnecessary security risk.
8. In the "IP Address" field, enter: 192.168.1.11 or your system IP address.
9. Click "Save Settings." Forwarding should begin immediately.
Apr 15, 2008 | Computers & Internet
Port Forwarding
First off, the have the wrong IP address set for the router. The 10.0.0.138 address they are shopwing you would be replaced by 192.168.0.1 (default for D-Link). You can always tell by going to the command prompt (start/run/cmd) then type "ipconfig". This will tell you the the default gateway (router) and the ip address of your computer. The 255.255.255.0 is your subnet mask. Now try following those very confusing directions.
In the D-link, forward ports in the DMZ or RIP section of the router.
Personally, I don't know Utorrent and would not open a hole in my firewall for it. Bit Torrent is the original and most trustworthy of the 'torrent" programs.
Dec 30, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
233 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
