2005 gmc w4500 with 6.0 engine automatic
SOURCE: transmission fluid capacity
Manual 6 quarts
Automatic depends on why it's being added. If bone dry try 8 quarts and check. Always check warm in no gear, if you can't be carefullllll not to over fill. Atf +4 is what dodge automatic. take
SOURCE: Transmission fluid capacity for 2000 Kia Sephia?
The four speed automatic shows a total fill (that is all the fluid it can hold) is 5.7 Quarts. So if you just dropped the pan and relplaced the filter, you shouldnt need more than 4 quarts and likely you would have a little extra with that.
SOURCE: how do you check/add transmission fluid to a 2004
Hello! To check the fluid level, the first thing you want to do is get the fluid to operating temperature, by driving it for a bit and letting it shift through all gears. Once you've done that you need to make sure you park the car on a very level surface. Remove the front passenger wheel and the splash guard. From there reference the picture below to give you an idea where the fluid check plug is located - there is no dipstick on this transmission (4T45e). You will also see the fill plug location.
If you do a pan drop and filter replacement only, the fill capacity is 6.9 quarts. You will want to use Dexron III type transmission fluid.
FYI - here are the torque specs for the pan bolts is 106 in/lbs and the check/fill plugs are both 124 in/lbs.
Hope this helps and good luck!
Testimonial: "i already found the info, but the answer is 100% cinsistant with the info i researched. thank you!!!! "
SOURCE: 05 Ford Explorer Transmission
on the bottom of the transmission pan you will find a nut with a hex or torx in the middle you remove the center plug when the truck is hot and running on a level serface the trans fluod will dribble out if it does not dribble out it is low if it runs out fast a steedy streem it is over full now their is a part that screws into this for a fill if you remove the pan you will see how it works the pan has a pipe/ stack that when full of fluid the top of the pipe is at the full point if you remove the large nut the stack and plug will come out the best way to change the trans fluid is take it to some place that has a fluid exchange equment this will get all the fluid out including the torque converter
SOURCE: Fluid capacity of a 4 speed auto in 1998 cavalier?
9.5 quarts
The check hole is located near the oil drain plug.
