Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Cd rom not working and computer keep on freezing
When i insert a cd into the drive it makes noise trying to read the disc but i cannot go into the disc and my computer freezes all the time.
  • 12 Answers
The best solution is you change your CD-ROM.
You haven't mentioned how old Much old your ROM is.
This problem occures after using a ROM for a couple of years.
I think the problem is with the lens of your CD-ROM. It is not very much repairable I think.
Posted on Jul 29, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Try and disconnect the cd drive first if this stop the frezing problem then get a new drive (CD). good luck
    President:
  • 1,383 Answers
Try with other disk if all disk getting same issue then you have to first clean your cdrom or dvdrom lense.
For that you need disk cleaner disk pur chase it and put in rom then play it.
then it clean lense.then check.
if still face problem then you need to repair or replaced lense if it in warrenty replace it.
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
Hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Jul 30, 2009 | HP Computers & Internet
When i put a disk in the cd rom keep getting message please insert disk
Try known good disk. Other than that the unit has probably failed. Make sure disks can be read on a buddys computer?
Jul 28, 2009 | Dell XPS 400 PC Desktop
My laptop cd/dvd can't read disc when inserted
may be your cd/dvd rom is weak. replace the dvd rom.
Jan 25, 2009 | EA Sports Tiger Woods PGA Tour 07 for...
No disc present
Try running a cleaner disc in the unit if that doesnt work try the following.
Starting at my computer... Right click on my computer icon.
Go to properties.
Then Hardware tab then go device manager. Right click on cdrom in device list. Select uninstall then reboot the computer. If this doesn't help replacing the unit will be necessary.
Jan 19, 2009 | LG GCC 4480B CD-RW/DVD-ROM Burner
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
Nov 02, 2008 | Dell Inspiron 9100 XPS Latitude D400...
I can't get the computer to find a cd or dvd, it keeps saying please insert disc - but its already in there.
Your driver(s) may be corrupt. Try this. RIGHT click on MY COMPUTER from your desktop, select PROPERTIES from the drop down menu, select the HARDWARE tab, click on the DEVICE MANAGER button, click on the (+) by the DVD/CD-ROM DRIVES line, RIGHT click the drive that isn't working, (this part may sound scary) select the UNINSTALL option, click OK in the warning box, then restart your computer. On restart, WIndows will automatically detect the deleted DVD/CD-ROM drive and will install the appropriate non-corrupt driver(s). This should solve your problem. If not the drive may be defective. Hope this helps!
Jul 18, 2007 | Acer Aspire 3000 Notebook
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
127 people viewed this question
Alun Cox
