Question about Maax Home
Best cleaning procedure for MAAX soaker tub. Presently use bathing soap and wash cloth for cleaning after use. This procedure works just OK but doesn't do the best job. Difficult to remove some graying spots. Any product suggestions?
  • 117 Answers
CLR or simple green always works nice with a soft wash cloth
Posted on Jul 29, 2009
Washer can't remove the soap , and have to wash the clothes handly to clean soap
Remove the soap build up between the wash tub and the outer basin with a fridge or dryer lint brush. The soap accumulates and builds up between the two tubs. Clean it after a recent load of laundry so it has a chance to soften up. Make sure the washer is unplugged when you clean this area.
Use Borax and half the amount of soap in future wash loads to prevent this build up.
Mar 23, 2014 | LG Washing Machines
Tip
HANDY TIPS AND TRICKS....!!!! Check it out
1) For removing perspiration stains from shirts and other clothing soak it in Vinegar and warm water.
Then clean as usual.
2) For removing mild-dew form the shower and bath tubs use products containing Phosphoric acid.
3) Remove build up from the shower doors wipe it with LEMON OIL..It prevents it from the future buildup
as well.
4) Dusty and dirty mini blinds can be cleaned in a snap....just fill the bath tub with warm water and soap
and soak the blinds....for white blinds add some bleach as well to the water.
5) For cleaning Ceramic tiles just pour some Isopropyl alcohol over it and rub nicely with a mop. Make sure children
are out and room is well ventilated.
Just follow these certain handy tips and tricks as they works wonders for your home.....!!!!!
on Apr 09, 2010 | Home
How do I get the top off the Washing Maching to clean the outer tub ???
use liquid soap the solution would be to pull the tub out and manually clean it.
Nov 12, 2011 | Washing Machines
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
Moldy smelling clothes
First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
Jul 01, 2009 | LG WM-0532HW Front Load Washer
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
There is an odor after the cloths are washed
You have a build up inside the washer. When it gets wet, it smells. When it dries out, the smell goes away. To solve this, first use 3 tables (one package) of AhFresh, or washer magic, or whirlaway, set washer on tub clean cycle if you have that cycle, or if not, use the hottest and longest cycle you have. Run cycle with no clothes. Now, to prevent this from reoccurring, make sure you use only ONE TABLESPOON of detergent or less per cycle, and only ONE TEASPOON of fabric softener per cycle if you use it. These washers use only a very small amount of water per cycle, and you must adjust additives accordingly to prevent odor and other problems. This is the number one problem people have with their front loading machines, and is 100% preventable! NOTE: You probably have soap residue left in your clothes. Try washing them with no soap once with to see if you get any suds in washer. You should see none if there isn't any remaining residue. Bath towels are usually just used to soak up clean water off your clean body. Don't use soap when you wash them. They don't need it.
Oct 14, 2008 | LG Washing Machines
Home Logo
577 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
