We have a model # SHC09DA0000AA0A which needs a condensate pump. Can you direct me to a supplier?
    President:
  • 2,559 Answers
These pumps can be purchased at most home repair centers such as lowes,home depot,etc..
and most hardware stores as well.
Posted on Jul 29, 2009
Hotpoint Aquarius condenser dryer, TCM 580p. Where can I purchase a pump microswitch?
A local appliance parts supplier might be able to help. You also can go to www.repairclinic.com and enter Hotpoint TCM580P to see a list of available parts.
Dec 16, 2015 | Dryers
The difference between the heat pump and condenser
Well...they are kinda the same. The condenser is where the refrigerant is condensed from a gas to a liquid. When in AC mode this happens outside at the AC unit. (You ever put your hand over a running AC unit in the summer? Feels warm!). When in Heat Pump mode the process is reversed. Instead of condensing the gas to liquid outside (which creates heat) the condensing happens inside and helps warm the building up (with the help of the fan of course). So essential the condenser is where the gas is condensed into a liquid, which creates heat. A heat pump can reverse the direction of the flow and cause this condensing to happen either outside or inside.
This is a very watered down version of what happens but I hope this is sufficient for what you are asking.
Jun 29, 2014 | Goodman Heating & Cooling
I have an whirlpool gold ad50gpusb from canadian tire. The pump will no longer pump via the clear rubber hose and instead the water accumulates in the bucket. Do you know if there is a simple fix to...
For the others who follow
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
Sep 24, 2013 | Dehumidifiers
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
553670 PUMP PARTS
Little Giant was acquired by Franklin Electric.
Your model number does not come up on their site so you may have to contact them directly.http://www.franklin-electric.com
Depending on what you need, you may be able to substitute from another source. Bearings and seals and bushings are readily available from many sources if you have the diameters and widths and seal requirements. Good luck.
Sep 28, 2012 | Little Giant PCR-10 230 Volt Peristaltic...
Drain Pump missing one rubber foot. Where might I get another one please? Model #11042922200
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 05, 2011 | Kenmore Elite 45986 Front Load Washer
I have an U-Line model # WCM48A that has a water reservoir/pump. I removed the reservoir/pump and directly connected to the home water supply. Previously the icemaker worked fine but now neither the...
the condensate drain pump will shut unit down and only run drain pump if over fill is seen may be noise you are hearing
if condensate pump removed has to be wired so kill switch in drain pump is over ridden for gravity drain
Nov 02, 2017 | U-Line Refrigerator Ice Maker
I wish to purchase DDR606 dehumidifier. Will need to place a pump into bucket to send water up basement wall and out thru window. Will this work with this model? Thanx!
This will work for all models. You just need to get a condensate pump. Hook drain from dehumidifier to the condensate pump. the dehumidifier will need to be higher than the pump so it can drain.
Nov 29, 2008 | Danby DDR606 Dehumidifier
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
