Question about Maytag MDE2400AYW Neptune Electric Dryer
No heat the dryer works, but there is not heat. used ohm meter to test coil for continuity, there is continuity. don't know if that means it's not the heating element. is there a relay? how can i tell if it's the thermostat?
    President:
  • 1,776 Answers
Check the thermal fuse. It is located just inside the back of the dryer and is usually mounted on the exhaust duct. It is about an inch long. Check it for continuity, If it has none it is bad and must be replaced. Hope this helped and best wishes.
Posted on Jul 29, 2009
Dryer only heats up sometimes
rate these please
Instructions
  1. For Gas or Electric Dryers
    • 1 Check the setting on the dryer. It's a simple thing, but sometimes people forget that they turned down the dryer for a delicate load.
    • 2 Check the fuse box. Electric dryers require 240 vaults to run, which means they have a dual breaker switch. If one of the breakers clicks off, the dryer has enough power to run but not enough to produce heat. You may need to replace the fuse to prevent this from happening again.
    • 3 Check the outlet with a volt meter. As said earlier, electric dryers require 240 vaults to run. If there is not enough power to the outlet, but the fuses are fine, then there is a problem with the wires in your house. You will need to call an electrician.
    • 4 Check the thermal fuse. Depending on the type of dryer, this fuse will be located either in the front of back of your dryer. It is usually an inch long and mounted in white plastic. Test the fuse using a continuity meter. If the fuse has been blown, replace it.
    • 5 For electric dryers, locate the heating element on your dryer and test it for continuity using a continuity meter. If it is not working, you will need to replace it.
    Gas Dryers Only
    • 6 Check the igniter using an ohm meter. Disconnect the clear plastic connector (called a molex) that attaches the igniter to the burner circuit. Place the probes of the ohm meter on the contacts. It should be below 100 ohms of resistance. If it is above 100 ohms, replace the igniter.
    • 7 Using an ohm meter, test the continuity between the two contacts on the flame sensor. If there is no continuity, replace the flame sensor.
    • 8 If none of the above works and you notice that your dryer starts out hot but finishes cold and/or you hear a chattering sound when running the dryer, then your problem is likely with the coils. There is no test for the coils. Your only option is to replace them to determine if this is the cause.
Jan 15, 2013 | Admiral Dryers
Tip
How to Troubleshoot a Clothes Dryer with No Heat
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Volt meter Continuity meter/tester Ohm meter (gas dryers)</span> </li></ul> <ol> For Gas or Electric Dryers <li> 1 Check the setting on the dryer. It's a simple thing, but sometimes people forget that they turned down the dryer for a delicate load.<br /> </li> <li> 2 Check the fuse box. Electric dryers require 240 vaults to run, which means they have a dual breaker switch. If one of the breakers clicks off, the dryer has enough power to run but not enough to produce heat. You may need to replace the fuse to prevent this from happening again.<br /> </li> <li> 3 Check the outlet with a volt meter. As said earlier, electric dryers require 240 vaults to run. If there is not enough power to the outlet, but the fuses are fine, then there is a problem with the wires in your house. You will need to call an electrician.<br /> </li> <li> 4 Check the thermal fuse. Depending on the type of dryer, this fuse will be located either in the front of back of your dryer. It is usually an inch long and mounted in white plastic. Test the fuse using a continuity meter. If the fuse has been blown, replace it.<br /> </li> <li> 5 For electric dryers, locate the heating element on your dryer and test it for continuity using a continuity meter. If it is not working, you will need to replace it.<br /> </li> Gas Dryers Only <li> 1 Check the igniter using an ohm meter. Disconnect the clear plastic connector (called a molex) that attaches the igniter to the burner circuit. Place the probes of the ohm meter on the contacts. It should be below 100 ohms of resistance. If it is above 100 ohms, replace the igniter.<br /> </li> <li> 2 Using an ohm meter, test the continuity between the two contacts on the flame sensor. If there is no continuity, replace the flame sensor.<br /> </li> <li> 3 If none of the above works and you notice that your dryer starts out hot but finishes cold and/or you hear a chattering sound when running the dryer, then your problem is likely with the coils. There is no test for the coils. Your only option is to replace them to determine if this is the cause.<br /> </li></ol>
on Dec 29, 2010 | Dryers
My dryer has stopped heating, so how do i know if its the actual element that is bad or the thermostat? i am guessing there is a thermostat that turns on the element? thank you ahead of time.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
This is a FREE answer, Please rate me
Sep 30, 2010 | Amana DLE330RAW Electric Dryer
Dryer does not heat. How do I get to the element?
Sep 29, 2010 | Roper RGK2951W Gas Commercial Dryer
No heat
Sep 26, 2010 | Frigidaire Electric Dryer
No heat
Sep 26, 2010 | Kenmore 600 6965 Electric Dryer
MY DRYER WONT HEAT UP
Sep 26, 2010 | Maytag PYE2300AY Electric Dryer
How do i get to the heating element of my dryer
Sep 25, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer is not heating
For this FREE answer, Please rate me
Sep 22, 2010 | Whirlpool WED8500S Electric Dryer
My dryer no longer has heat
Sep 22, 2010 | LG DLE2512W Electric Dryer
Maytag MDE2400AYW Neptune Electric Dryer Logo
264 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
