Download msi drivers from website. try this: http://eu.msi.com/index.php?func=html&name=liveupdate
What Os do you have installed? At firs you must enter to BIOS power on your machine and press DEL button bios will show up, then enter INTEGRATED PERIPHERIALS then enter AC'97 AUDIO and if it has DISABLE across it press + and it will change with ENABLED then press F10 to save configuration. Then when software runs find Device manager and if audio ras "?" mark download and install audio drivers from
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=582
May be you haven't installed the driver for your built in sound card. You should have a CD (given when you bought your PC) that includes all the driver for your motherboard. Try to install it.
May be that will solve your problem :)
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
