Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
    President:
  • 1,952 Answers
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Posted on Jul 29, 2009
  • don wehrheim Sep 20, 2012
    this is not the problem
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
GE Spacemaker microwave oven seems to have no power
look for white small fuse inside by power cord are on small board
Jan 04, 2014 | GE SpaceMaker Microwave Ovens
GE JVM1190BY died
The keypad control board may be the problem, or the inverter board if 7 years old or less, cost should be considered.
Apr 29, 2012 | Whirlpool Microwave Ovens
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
I have a new (2009) microwave GE JVM1750SM1SS and suddenly turn off. I turn off and back on the microwave main breaker. I checked the outlet and it has energy. I plugged in back the microwave but it...
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Dec 30, 2010 | GE Microwave Ovens
Turned on the microwave and all power just went out. Checked the breaker panel, but none are tripped.
when you said the power went out ( did you mean to the micro or the complete hm . if only to micro it probably blew it internal fuse . they doo that . replace the fuse ( radio shack is a good place to get it .) but ck the door inter lock's as they may have caused the failure . ps buy more than one fuse / you may need more. **** ,,
Dec 23, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Ge spacemaker jvm1533 is dead wont turn on
check the circuit breaker first it may be the fuse is blown The fuse may be located behind the grille following the power cord on the rside of the unit.
it may be a bad thermal fuse or oven thermostat.
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag Microwave Power Outage - Model MMV5000BAB
Found this under GE instead of Maytag, but can answer for you here.
It may be the internal fuse, but more likely it is the thermostat on the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE JVM1190SY/WY/AY/BY Microwave Oven
Dead micro
It could be a bad in-line circit breaker fuse. Unplug the microwave and take the outside cover off. Look for the in-line circuit breaker fuse. Use a plastic fuse puller (not your hands or a metal tool as there is still voltage stored in the microwave even when it is unplugged). Look at the fuse and see if it is blown. (The metal wire running length of tube will be broken. If you have one, test with an Ohmmeter.
Jun 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,227 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
