Cars & Trucks Logo
James Beaudion Posted on Nov 12, 2017
I have a 1995 grand jeep Cherokee laredo and the lights won't work correctly sometimes they brighten when I hit a bump fog lights don't work all the time the switch won't even glow and the switch for the lights is really messed up I can turn it hard to right and they work fine not fog though but it won't stay there and sometimes I have to turn off lights by turning on and off again otherwise they stay on my tail lights say something is out but nothing is out back there it's says so on the computer dash board also my radio comes on and off when I hit bumps most of the time it doesn't work the buttons either
2013 Jeep Grand Cherokee Laredo won't shift out of 1st gear.
Question edited for spelling of the model names.
Question moved to model category.
Are you in Limp Mode? Is the Check Engine Light on?
Some ideas here including pulling fuses. You probably need an auto electrician though.
https://www.google.com/search?q=2013+Jeep+Grand+Cherokee+Laredo+won%27t+shift+out+of+1st+gear
Ok my 2001 Grand Cherokee Laredo wont stay in park
Transmission sticks in reverse- won't go into park. - JeepsUnlimited
www.jeepsunlimited.com/forums/showthread.php?...won-t-go-into-park
Jun 14, 2013 - 12 posts - ‎5 authors 2003 6 cyl 4x4 Grand Cherokee Laredo automatic- Occaionally, when shifting from REVERSE TO PARK, my Jeep will stay in reverse. Typically its ... '2001 WJ'4,0L'42RE'NV 242'380000 km'ECE Compliant' ??????????? ??? ...
2001 jeep grand Cherokee laredo - CarGurus
www.cargurus.com > Questions > Jeep > Grand Cherokee
CarGurusJan 27, 2014 - 2001 jeep grand Cherokee laredo - Just purchased a 2001 Jeep GrandCherokee Laredo and ... It starts in PARK sometimes and sometimes it won't and I have to start it in Neutral. ... Hatch shuts flush, but won't stay shut. help!
1helpful
2answers
2010 jeep grand cherokee laredo fog lights
If it didn't come with fog lights, it may also have not included a fog light relay and/or fuse. Check the owner's manual for fuse and relay locations, and then check if the necessary parts are there.
Dash lights and radio lights sometimes work or flicker when hit a bump. Any ideas?
Might be a loose battery cable. Just a thought. did see other post where you stated that you've disconnected battery several times. Hope you find/found a solution.
The warning lights for the brakes and ABS came on in my 2004 Jeep Grand Cherokee Laredo after I bumped a snowbank pulling out of the driveway. I shut the vehicle off and back on, but they're both still...
Yes it is. I would first look under where you hit. You may have packed snow/ice in between the sensor and exciter ring. or knocked a wire loose. these are located by the inside of the tire.
2helpful
2answers
My brake lights have completely gone out at the
2004 jeep grand cherokee, brake lights do not work, no power at fuse cavity 23 and the fog lights are also out but the dash indicator is working.
2answers
Wheels shake terribly on 95 jeep laredo when I hit a bump over 50
Get front end checked out a.s.a.p. as this could be a part ready to go, and steering could go with it. Steering link, tie rod end, idler arm all come to mind. Personally I wouldn't drive it too far if at all, and not at a high speed until I'm sure what it is.
1995 jeep grand cherokee laredo. Gets the death wobbles when going 50 or faster and hit a bump. Have to hit the brakes to make it stop.
Front shocks/struts may be shot...not dampening the blows from the street.
Also...very important... wheel balancing. Wheels that are out of balance will start bouncing like this too.
Also check alignment if it's only when you hit a chuck hole.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
