Question about Dyson Vacuums
My Dyson stick vac isn't cleaning as good as it used to looks like the brush roller needs replaced Where can I buy one please
  • Dyson Master
  • 1,545 Answers
From any Dyson service or warranty center. I can check if you give me your model number to see the price and availability.
Posted on Nov 12, 2017
geordie rob
  • 7 Answers
SOURCE: roller brush is not turning on a dyson DC14
http://www.dyson.co.uk/support/help.asp?product=DC07-SY&article=527
here's a link that might help
good luck
Posted on Dec 29, 2008
SOURCE: DC15 Animal brush motor not working?
Just had the same problem. Switches and motor checked ok, then found the circuit board on the left hand side of cleaner. The fuse (on the board) looked ok, but when removed and checked for continuity I found it had blown. The problem I have now found is that the fuse cannot be ordered only the complete board. Hope it gets the brush roller going again.
Posted on Jun 01, 2009
wentlanv
  • 710 Answers
SOURCE: dyson vac has started to
Does the whining noise come from the motor or the brush area?
If it's from the brush area, it's probably the belt. Check to be sure the belt is not worn. Sometimes belts will glass up and slip. Also, check to see if it is still completely on as it should be. You may need to replace the belt.
I woHope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Posted on Mar 28, 2011
Testimonial: "good answer"
  • 20 Answers
SOURCE: brushes are not spinning
One problem may be that two small wire are broken that control roller functions. See solution with photos at http://bajwa.net/content/dyson-dc15
Posted on Jan 12, 2012
small6363
  • 18425 Answers
SOURCE: dyson dc 41 roller brush will not turn
You can download a .pdf copy of the DC41 user guide directly from our website:
http://media.dyson.com/downloads/us/floorcare/manuals/DC41_OPMAN_US_181011.pdf
Please note, for information on assembling, using and maintaining your machine, you can also find help guides and videos on our website:
http://www.dyson.com/support/help.asp?product=DC41-IRSPU&article=32
Posted on Sep 27, 2012
Dyson DC27- machine stays on with red button but beater brush won't stay on while vacumming low carpet.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 10, 2017 | Dyson DC27 Bagless Upright Vacuum
Dyson dc50 the roller head stops spinning after
Hi, it's Jim from Crucial Vacuum!
One of the main reasons most brush rollers begin to get jammed and eventually not turn would be due to a clog. Turn off the vacuum and flip it on its side. Is there any noticeable debris,such as hair or large carpet fibers? If you're looking to clean out your brush roll do the following. For the DC50 there should be a red button below the vacuum and just above the brush roll. Push this red button, this will allow the brush roller to be removed. On the brush roller itself you'll notice two more similar looking red switches. Flip these up allowing you to remove the top of the roller and gain access for cleaning. Clear out any debris and try rotating the brush roll once around to see what else may fall loose. Take note of how the bristles look too. Are they worn down and loose? If so it may be time to change your roller.
This handy video may further help in troubleshooting your Dyson.
https://www.youtube.com/watch?v=HpWk5trjvO4
Another item to check would be your vacuums belt. If this is loose as well it can affect your vacuums brush roll. Both are simple and easy fixes and can be done in just a few minutes.
Should you need any replacement parts for your Dyson in the future please feel free to order direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Check out our lineup of Dyson replacement parts at the below link.
http://www.crucialvacuum.com/dyson-vacuum-parts.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Oct 18, 2014 | Vacuums
The brush on my dyson vacuum won't turn, and the
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Feb 24, 2012 | Vacuums
Ball makes a clicking sound and brush isn't turning
Check the brush. That could be the problem. Check the belt also. Your brush roller may need to be lubed or even replaced.Turn it over and wipe all the black residue off the bottom of it.------ Either the brush is getting clogged and blocked by dirt, hairs etc etc and that needs to be cleaned or the brush bar motor is got faulty and needs to be replaced.------- You can yourself replace this motor,m if its not running.------- To get instructions to disassemble the vacuum and replace the motor, click this link below :--- http://howtobyme.blogspot.com/2011/08/brush-not-turning-on-dyson-ball-dc24.html----------- This will-help.Thanks.Helpmech.
Aug 25, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I replaced the clutch in the dyson dc14. it isnt making that terrible noise anymore....thank god!! but the roller brush is not moving when the vacuum is in use. whats wrong?
The "horrible noise" you were hearing before wasn't the clutch! It was the roller brush. If the brush is not turning, all you are doing is burning out your new clutch. Reasons for the brush not turning: there is hair, carpet fiber or other matter wrapped around the brush that needs to be removed. Remove the roller brush, inspect it, and remove anything that could interfer with it's functioning. Reinstall and give it a test.
But in my experience, the brush needs to be replaced. Remove the brush and look for cracks in the plastic, If you see any, it needs replacing. eBay, via a distributor from England, is your best bet as far replacing the brush. Be careful of non-original brushes as they will break easily and are not of the same quality as the originals. Try searching for "DC14 brushroll" and then go down to the International Sellers at the bottom of the page.
Do not continue using the vac until you have solved the problem. You will only have to replace the clutch again.
Sep 22, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson eats my carpet
When using the Dyson or for that matter any other vacuum cleaner that has a motorized roller brush, you need to make sure that you AVOID open carpet edges since the suction end ( which has a roller with the brush) will grab open fiber ends. You should use an attachment or floor tool when cleaning open edges of your rug or carpet. Most vacuum cleaners come with a range of attachments that be used be used appropriately.
Sep 16, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 brush roller is worn and won't make contact with the carpet anymore. I need to replace the brush roller but don't know how...HELP?
Buy the brush over the web etc..
To take the brush out
1 - Take the outer covering - uese a penny to turn the yellow srews
2 - Slide the black brush out from the assembly - Try the non belt side first.
3- Slide the belt out of the brush.
4 - Take brush out - Replace it with new one.
May 09, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
