Question about Sony Playstation 3 (PS3) Console
PS3 will not boot up, red light is on, will go to green for awhile then drops back to red
  • 22 Answers
Excerpt from the PlayStation 3 Manual:
The power indicator on the system front is flashing red and green alternately.
*The interior of the system has become hot. Check whether the system is being used in a hot location or whether the vents are blocked. Continuing to use the system in the above condition will cause it to stop functioning. Turn the system off and leave it unused until it cools down. After the system cools down, turn it on again.
The power indicator on the system front is flashing red and the system does not operate.
*The temperature inside the system has risen too high. Check whether the system is being used in a hot location or whether the vents are blocked. Touch the power button on the system front to stop the flashing, and then leave the system unused until it cools down. After it cools down, turn on the system again.
If this does not resolve your issue, you may need to send it in for a repair.
https://service1.us.playstation.com/rma.htm
Posted on Jul 30, 2009
Turn ps3 on light goes green then flashes blue then back to red
PS3 turn on goes green then flashing red is not a new issue. Please read this post and you can find the solution :
PS3 Red Light Blinking Fix
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
Green light then red/green light then flashing red
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation 3 back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
My 12th old ps3 has been faultless until 6/2/10 .It will not boot up at all .The start up red light turns to green as per normal then after 2 seconds it flashes red and goes back into stand-by mode Any...
That is the PS3 "Red light of death"
The articles below could help you fix them :)
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Any time i turn on my ps3 it will turn off
HI If the light turns yellow then red, this is a overheating issue. let it stand for an hour unplugged to cool.
Now, if the green light doesn't turn yellow before red, this will confirm that the HD(Hard disk), is experiencing some difficulties with the booting process. This will occur if the internal connections are damaged, due to a solder break. In this case, you will need to send the unit to Sony for a repair. Try removing the HD from the unit. after the unit HD is removed for a minute and re-installed, try to power up and initiate a boot. if the unit continues to not boot and flashes the red light after the HD is pulled, this will confirm that the HD is the culprit.
Contact Sony for a repair ticket if the problems persist.
Oct 03, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont boot..PLEASE HELP!
It's the Yellow/Red Light Of Death. It can be fixed. Go here http://playstationlifestyle.net/forums/showthread.php?t=2376. Follow the videos. A little bit of time and you should be back up and running.
B
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
When I turn on the PS3 the green light comes on for a few seconds and then goes back to red. I cannot eject or insert a disk
It's a hardware problem.
You can try booting the ps3 with the hard drive out.
Otherwise google my username and my blog will come up with a bunch of info on how to fix PS3 problems.
Best of luck!
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
From standby PS3 wont turn on.
that sounds like your main power supply unit
May 28, 2009 | Sony Playstation 3 (PS3) Console
Wont boot fully boot up.
Try reseting your PS3. Turn your PS3 completely off by the switch in the back. Then flip the switch back on. Press on the power button and hold it until the green light comes on, beeps twice then the green light should go out, replaced by a red light. Then turn it on normally.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
752 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
