Question about Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range
Belling DB3 Main oven door falling off its hinges
Main oven door falling off its hingesThe repair quote for the hinge excl. door is huge!Any suggestions?Thanks Rik
  • 1 more comment
  • seanriley Feb 09, 2008
    My Belling db3 also has its main oven door falling off its hinges. I can't see any easy way of fixing this. Any ideas?
  • Anonymous Apr 09, 2008
    Bending the lower hinge upwards with pliers solves the problem but only temporarily.
    I also have a problem with the control panel markings wearing off with cleaning. Any suggestions?
  • Anonymous Jan 09, 2009
    the
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Posted on Mar 14, 2008
SOURCE:
Belling stove door wont close properly how do I adjust the hindges.
open the door and readjust them using a philips head screw driver.....
Jul 10, 2018 | Belling Ovens
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
Belling g756an
Get a strong magnet and try to move the plate up and into position.
Dec 15, 2013 | Belling Ovens
The main oven door will not shut tightly, how do you adjust it?
if its a pull down door the hinges are prob worn and need replacing.
Sep 27, 2009 | Belling XOU492 Electric Double Oven
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
My belling oven door
get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Jan 29, 2009 | Belling XOU487 Electric Double Oven
Belling oven door not closing fully
Hi. Yes, you will need to replace hinges, and possibly the hinge guides located inside the cookere.
Oct 17, 2008 | Belling XOU252 Electric Single Oven
Belling db3 oven
yes its most likely the element they are common in burning out ....because the fans still running,
Dec 17, 2007 | Ovens
Belling DB3 Control Panel
Not easy. Briefly, in addition to the screws you mention, the cooker side panels need to be removed to give access to removal of the control panel side clamps. Then the indicator lamps have to be disconnected, and timer etc. buttons have to be pulled out to allow removal of the the control panel. Then the main control unit (timer etc.) needs to be unscrewed from behind the control panel.
Replacement is reversal of above.
Oct 27, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,179 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
