Question about Homelite Leaf Vac Attack
Plug is ok but will not get gas - Homelite Leaf Vac Attack
    President:
  • 986 Answers
Diafram is bad
Posted on Jul 29, 2009
Ram 3500 will not start batt ok turns over ok
Only two things can cause this (1) not getting gas and or (2) not getting spark.
Have someone crank while you hold spark plug wire just of off spark plug, if you see spark from wire too motor block then put a little gas into carb and see if it fires if it fires then look for a gas line or gas tank problem.
Nov 02, 2017 | Cars & Trucks
Cleaned my gas hob but now when you turn the gas on the automatic ignition doesn't switch on. Model candy pl 40 ax. I have checked the fuse on the plug but that's ok is there another fuse I should kno
Is it pluged in. Check to see if the plug Still works behind the stove It might be on a GFI plug needs to be reset somewhere along the backsplash counter
Jul 19, 2013 | Cooktops
Just pulled my 01 Buell Blast out to ride and it won't start. It tries but doesn't fully turn over. Gas ok, battery ok, dash n lights ok. Not sure if maybe there is a problem with my gas line??? Please...
have you checked the spark plug?
remove it and plug it into the ht cap then lay it on the chassis touching metal and turn over bike if its working you will be able to see the spark
john
Jan 23, 2011 | 2000 Buell Blast
Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
May 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Battery was dead, charged; engine will turn over, but not crank. Spark plugs ok, fuel filter ok, fuel pump ok. When I try cranking, strong gas smell. Mower has 30 hours on it, one and a half years old.
Try taking gas line off pump that goes into carb. Crank it, if gas won't come out, tap on fuel pump. If gas still won't come out after tap it with a wrench. Either replace fuel pump or check gas lines making they are free.
Feb 21, 2010 | John Deere 42 in. EZ Trak Bagger
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 25, 2009 | Craftsman Garden
Alt seems ok but strong fuel smell and new plugs black
use a scanner sound like a bad sensor .mass air flow - map sensor - coolant sensor. check vacuum line to fuel pressure regulator if wet with gas replace fuel pressure regulator. make sure yours spark pluge the right heat range. also change air filter. check charcoal canister. check oxygen sensor and egr valve. make sure its not stuck open.
Mar 25, 2009 | 1994 Saturn Sl
Roper gas dryer not heating
the glow plug (ignitor)must draw 3 amps or more to function properly if its ok check the flame sensor for continuity located on the side of the burner housing and if its ok then the gas coils on the top of the gas valve are faulty let me know if this helps
Sep 11, 2007 | Kenmore 74962 Gas Dryer
Homelite Leaf Vac Attack Logo
139 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
