Question about Maytag Neptune MDE7500AY Electric Dryer
How do I replace a heating element for a Frigidaire Gallery Series Dryer (Mod GLEQ 332as2)?
Don't got much for a repair bill, but I'm 99% sure its the heating element, I can do it myself if shown thru instr. Can the experts lend me hand, would appreciate any info..
Already got the part, just don't want to mess up the dryer...
Need to know how to get to heating element and replace...
Thanks in advance to the experts for any info !!!
Ben ....bmniners@gmail.com
  • bmniners Nov 25, 2007
    Thanks Guru for the reply, the dryer runs good with power and everything, but no heat. The air blowing out of the vents doesn't get warm at all. My bad on not including the model and make. Here it is :
    Frigidaire model : GLEQ332AS2
    Serial : XD33404180
    As usual, your response is always highly appreciated...Thanks again !
    Ben...bmniners@gmail.com
  • 447 Answers
How are you sure its the element??? Its usually not. Ill be glad to help let me know how youve checked it??
Posted on Nov 23, 2007
  • joey  shearer
    joey shearer Nov 23, 2007
    Also is it a maytag ???? Or frigidaire?? Model # would help
  • joey  shearer
    joey shearer Nov 25, 2007
    You will need to start by lifting the lid to the dryer. There are two clips that need to be released by pressing them in with a putty knife or similar tool inbetween the front panel and the top. Once the lid is up there are two phillips screws holding the front panel on. Undo door switch wiring remove screws and remove front of dryer. Once front is removed release belt from idler, motor. (this can be done thru small louvered panel on rear of dryer). Now use belt and pull up on tub until rear bearing is released. Now the Element can be axcessed. You may want to pick up some Frigidaire High temp grease for the rear bearing. Also inspect the 3 White Plastic Front Tub glides or if the front of your dryer has a big plastic ring around the enitre opening this is the glide. Inspect for wear and for cracks.
2 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: How do I replace a heating element for a Frigidaire Gallery Series Dryer (Mod GLEQ 332as2)?
please ask for Premium-Assistance:
Posted on Feb 13, 2009
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Model #ALFRIGLEGLIS152ES Frigidaire gallery series won't heat. It stays on for a while and sometimes cuts off. When you set the time on it and press start all the lights start blinking on the o
Hi Robert Burch - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 12, 2012 | Frigidaire Electric Dryer
My frigidaire gallery oven dosn't heat up.. but element of OK
oven is controled by the clock it may be bad . if element is ok ck wiring and connections on back and make sure that both lines are working ( tha t 220 volt art there ) if if so replace the e o c // the clock ..
Oct 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
My frigid air dryer turns on and tumbles but will not heat up. We are doing renos and the duct(ing) is not connected to the dryer vent. Is that the cause? thanks.
No probably not the reason for not heating, what comes to mind first is check for proper 220/240 voltage is getting to the dryer, a dryer will run and seem to operate normally evn with getting only 110/115 volts but that is not enough power to energize the heating element to heat the air blowing into the dryer,or you may have a failed dryer heating element. Good luck !
Nov 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Dryer not heating, help
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
May 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer problems
do have the the seting set to air dry? or possible a sensor issue or maybe the heating element at the back has not bee connected or has shorted
Apr 26, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery series dryer will not heat
Hello spirit817. Unplug the 220v, remove the back panel, locate your heating element, check the wiring connections to the element. DVM or ohm your element for continunity. If open research your local electrical applance store for the replacement. If not the element check your thermostats located in the air drafts with the meter.
Sep 23, 2008 | Dryers
Maytag Neptune MDE7500AY Electric Dryer Logo
1,302 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
