Question about Samsung 793S 17" CRT Monitor
No Display on connecting Data cable of PC
The monitor shows "No Input Signal" in dialogue box when the data cable is taken out. The Dialogue box moves all around the screen. However, once data cable is plugged into the pc the dialogue box disappears and the LED at the On/ OFF switch kepps blinking on and off without anything on the screen. The CRT screen display is black/ blank. Please suggest what could the problem be. The monitor is just 3 & 1/2 Yrs old.
  • SPEEDSAMS Feb 13, 2008
    pls help meeee how to solve my problem
    Scholar:
  • 116 Answers
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Posted on Nov 26, 2007
A dialogue box on the insignia tv screen says no signal. Press input button on remote control. Then select the device you want to view. Be sure device is on.
what the message is telling you is to select the input source to use AV channel selection ( AV 1--AV 2--AV 3 etc )
antenna - dvd player , gaming console etc
Nov 26, 2016 | Insignia Televison & Video
My printer cannot print]
Cristyjoyxeg:
When you click on the print box, the next screen will have a small dialogue box naming the destination printer. click on the small arrowhead on the right side of the box and a drop-down dialogue box will appear with your printer identified in the drop-down box. click on the choice that shows your printer and then click "print".
Aug 11, 2012 | HP Office Equipment & Supplies
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card...
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Oct 27, 2010 | ATI RADEON 9200 Graphic Card
V505 Dell Printer Connected by USB
Try to check the USB in the device manager if did not disable. To goto device manager right click the My Computer on the screen and click properties. Dialogue box appears click on the Hardware and click Device Manager. Another dialogue box appear then just see at the bottom of the dialogue box if the Universal Serial Bus Controllers are did not have question mark (?) with yellow color. If don't have mark like that try to change your USB cable then insert it again to your printer. But if they have a mark like that you need to right click the Universal Serial Bus Controllers and click Update driver.
May 28, 2010 | Dell V505 All-In-One Printer
How do i get the monitor to work if i didn't change the settings on the 1st monitor
Assuming that you've just added a second monitor.
You need to go into the Display Settings, or Display Properties dialogue box.
In there go to the Settings tab.
You'll see two squares marked 1 and 2. select the second one, then lower down on the dialogue box you'll see a checkbox to enable "Extend my Desktop to this Monitor"
Check it and you're good.
With your mouse you can select each monitor, and drag them around to adjust how your two desktop displays will seem together, higher lower, left or right side. Experiment till you're comfortable.
Hope this helps.
Dec 11, 2009 | Computers & Internet
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
Connection between computer and monitor!!!
The cable for the monitor has to plug into the desktop. So it's a VGA cord or DV Cord depending on the type of video card you have on your desktop. Some have a built in VGA port. Make sure you connect this to your desktop.
12_17_2011_8_16_49_pm.jpg12_17_2011_9_02_50_pm.jpgThis is the cable
Jan 09, 2009 | HP Pavilion M9040N Elite Desktop PC
When energized, screen stays on for about two seconds then blanks
Hi...there,
Well, it's seems your monitor backlight inverter are bursted. Usually, the monitor had a 1 year for the screen panel and 3 years for parts and labors. You're still under warranty, send it back to manufacturer for repaired.
Nov 15, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Error: Will not print
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Feb 20, 2008 | Dymo LabelWriter 320 Thermal Printer
The screen will not turn on
Yes these Monitors encounter problems:
1. Bad Inverter
2. Burned out Backlight
3. Power supply issues
Sounds like your inverter board is bad and backlight will probably follow!
Nov 25, 2007 | Gateway FPD1810 18.1" LCD Monitor
Samsung 793S 17" CRT Monitor Logo
127 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
