Question about RCA R52WH73 Projection Television
R52WH74 with a convergence problem. I understand the solution is to replace the fl231 fuse and resolder somthing else. I have seen a video on youtube of how it is done. The fear I have is that I have never soldered anyting. Is that something I need to practice before trying the real thing and do you go about removing the old solder?
  • 167 Answers
Resolder the Flyback Transformer pins. It looks like a Black Hand Grenade with a red wire out of the top.You don't need to remove any old solder / Just place the tip of the iron on the connection and let it melt the existing solder and add more solder to it while still holding the tip of the iron on the connection / then remove the iron and go to the next connection.Should be about 9 pins on that transformer.Be sure to unplug the TV from the wall outlet 1st !
Posted on Jul 30, 2009
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
R52wh74 already changed 231 fuse still not converging
Did you change DL231 and CL230 with the fl231? Also did you reflow the solder on the flyback and vertical IC? Bad solder is what blows the FL231, but without changin DL231 and CL230 and resoldering the flyback and vertical the fix wont be fully effective.
Jun 12, 2009 | RCA R52WH73 Projection Television
R52WH74 FL231 FUSE
You will need to replace FL231, DL231 and CL230 you can get the parts at the following link with free instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 07, 2009 | Televison & Video
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
RCA R52WH74 Convergence Problem
Yes i replace that fluse fl231 all the time at the shop. at least two aweek. and the first few i replaced did the same thing. I would send it back to customer and i would get a call that the set had malfuctioned again and convergence gone. It was determined the reason this fuse blows is bad conections on the flyback transformer. The flyback is the big black component with the red wire coming out of the top. if you examine the connections on this component there will more than likely be a ring in the solder. this is caused by the manufacturing process known as LEAD-free solder. THis cause oscillations in that cuicit. like turning it of and on really fast. this is a very small fuse and cant stand up to this. so when you replace this fuse just simply RESolder these connections apply a little amount of solder to these connection. i am confident this will fix your problem.
Sep 10, 2008 | RCA R52WH73 Projection Television
Rca r52wh74 - no auto convergance
you need to replace chemical type fuse marked FL231 part number 259213, it`s located next to the flyback transformer, theres 3 of them there but 231 is the only one I`ve seen cause your problem, replace it and you`ll be all set.Happy Holidays !
Nov 29, 2007 | Televison & Video
RCA R52WH73 Projection Television Logo
438 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
